02-29-2012, 09:11 PM | #1 |
Newbie Join Date: Feb 2012 Location: round rock
| problems with new wraith
i just bought my wraith and within 30 mins of crawlin the spur gear stiped out. has this happend to anyone else? and what else should i upgrade now before anything breaks
02-29-2012, 09:14 PM | #2 |
Quarry Creeper Join Date: Nov 2011 Location: Plano,TX
| Re: problems with new wraith
Kit or RTR? When you replace the spur - check the pinion and spur mesh.
02-29-2012, 09:16 PM | #3 |
Newbie Join Date: Nov 2011 Location: broadlands
I bought a wraith last week and only drove it for about a minute before i switched out the engine. I did notice that the pinion gear was barely tightened and had lots of play. That could have been your problem. I would go thru it and check every nut, bolt screw etc...
02-29-2012, 09:30 PM | #4 |
| Re: problems with new wraith |
02-29-2012, 10:29 PM | #5 |
Rock Stacker Join Date: Dec 2010 Location: junction city
i have seen them new right of the box with a loose pinion also
03-01-2012, 04:46 AM | #6 |
Some of the Axial trans I have seen have a ton of back and forth play in the upper trans shaft, making it so that at times less than half the width of the spur is contacting the pinion. This will cause premature spur failure. Some 5mm ID shims on the upper shaft underneath the slipper drive pin will take the play out.
03-01-2012, 08:32 AM | #7 | |
| Re: problems with new wraith Quote:
03-01-2012, 08:43 AM | #8 |
Newbie Join Date: Dec 2004 Location: Phoenix, AZ
Check the two screws that hold on the knuckles also. Mine were loose and actually had the upper screw back all the way out last weekend and lost the flange pipe. I checked the opposite side at that point and it was way loose as well. Anybody ever try to locktite metal screws to plastic????? I thought about trying that or even a small dab of super glue and see what happens.
03-01-2012, 08:51 AM | #9 | |
03-01-2012, 11:42 AM | #10 |
problems with new wraith - Similar Threads | ||||
Problems with Castle BEC on Wraith | TW31 | Axial Wraith | 8 | 01-31-2012 01:11 PM |
wraith problems | popeye123 | Axial Wraith | 13 | 01-13-2012 01:18 PM |
Wraith throttle problems | sixhundred71 | Axial Wraith | 4 | 12-31-2011 08:53 PM |
new wraith esc problems | mrallen0 | Axial Wraith | 3 | 12-03-2011 09:02 PM |
Wraith Speed Problems!! | WarTrader | Axial Wraith | 12 | 08-29-2011 10:59 AM |
