09-23-2012, 04:47 PM | #1 |
RCC Addict Join Date: Mar 2009 Location: Interior BC
| cogging with tekin 13.5t?
i recently got the tekin 13.5t sensored motor and installed it on my vxl3s esc. the gearing was brought down back to 38/13 at the axles and my spur/pinion is 54t/14t (32p). why would it be still cogging at REAL slow speeds? is it still my esc?? damnit....and my gearing i think still needs to be lower but not sure where? im guessing the spur/pinion as i dont think theres any other options lower then axials 38/13 right?? thnx in advance |
09-23-2012, 05:07 PM | #2 |
Pebble Pounder Join Date: Sep 2006 Location: Myrtle Creek
Does it have a sensor port? I tried Googling pics and info I didn't see one. If it does then check and make sure its plugged in all the way.
09-23-2012, 05:31 PM | #3 |
| Re: cogging with tekin 13.5t?
yupperz....the sensor port is right up front behind a plug. so its all there but i would think it shouldnt cog at all, but im new to crawling so??? |
09-23-2012, 05:40 PM | #4 |
Yeah if everything is connected correctly then you may have a bad phase in the esc. The gearing might be an issue if you were up in the 20 tooth range. But at 13 I wouldn't see it as an issue. Or you could have a bad rotor. I had a sc4x motor from tekin cogged bad ended up being a weak rotor.
09-23-2012, 05:44 PM | #5 |
Rock Stacker Join Date: Dec 2011 Location: Marietta, GA
Behind a plug? Does that mean you don't have a sensor cable connecting the motor and ESC? With a sensorless ESC or no sensor cable connection between the ESC and motor then the ESC has to "guess" where the motor is and that's what causes cogging.
09-23-2012, 05:45 PM | #6 |
Quarry Creeper Join Date: Nov 2009 Location: Hickory,NC
I had the same problem with a VXL esc and a Novak Ballistic 4.5. My problem was that the sensor wire was not plugged all the way into the esc. The rubber seal fits tight around the sensor wire plug. After I pushed the plug in all the way it ran great.
09-23-2012, 07:02 PM | #7 |
gain, yes...it has a port for the sensor wire on the VXL3S ESC ill try to push them both in and see?? thanks again!! |
09-24-2012, 04:12 PM | #8 |
Newbie Join Date: Apr 2012 Location: under a rock
try a different sensor wire.
09-24-2012, 06:51 PM | #9 |
I wanna be Dave Join Date: Jun 2008 Location: Sin City
Mine cogs too - but i am on the mmp. I think some is just going to be there. Without a video I cant tell you if you have more or less than me though.
09-24-2012, 09:05 PM | #10 |
RCC Addict Join Date: Nov 2011 Location: the not so white north
I set my buddies wraith up with a mmp and tekin 13.5 with 12/56 32p and it seems to be great with no real noticable cogging. Compared to my pro4 it is almost as good but he was on a budget so the 13.5 is more aforedable.
09-24-2012, 09:10 PM | #11 | |
| Re: cogging with tekin 13.5t? Quote:
i pushed both connectors in firmly without any noticeable difference on ESC/Motor. if worse comes to worse ill end up goin to a Tekin esc or such with drag brake anyhow. without drag brake is a bitch! | |
09-24-2012, 11:03 PM | #12 |
Drop it as low as you can and still get a decent mesh. If you still have really bad cog then post a video so we can see.
09-25-2012, 02:50 PM | #13 |
Pebble Pounder Join Date: Feb 2006 Location: The Hive...
I had this problem before but with a MMP an 32pitch. The problem I "think" is the axial radio. I put ah gt3b on, an it runs smooth. Plus your gearing is to small. A 56t to 60t is what I would recommend. 60 is what I use, but you can't use the spur cover, but keeps the heat down with ah 4000 pack till it's dead. Last edited by muddauber jr; 09-25-2012 at 02:56 PM. |
09-25-2012, 03:01 PM | #14 |
Rock Crawler Join Date: Jan 2006 Location: Derbyshire UK
I am running a MM Pro with Tekin 10.5t motor standard gearing and it has no cogging at all.
09-25-2012, 03:38 PM | #15 |
now im not sure? lol so, i should get the 54t/32p out and drop a 56t/32p and run what.....still my 14t pinion? or should i change this dfferent aswel? as for the radio....i know im still running a POS HPI TF-2 but i use it cuz its a 3CH....only one i have currently! all my other TX/Rx are 2CH systems, and i plan on getting the DIG for this RIG. Self-edit: i do have a 4CH LanSu but i cant figure German out or this Tx! ahah at low-end speed (nearly at a turtles pace) it seems to sometimes have a deadspot or something and a slight Cogging goin on? ive made sure the sensor wire is firlmy pressed into both the ESC/motor. hmmm Last edited by SwampDawg; 09-25-2012 at 03:40 PM. |
09-25-2012, 04:18 PM | #16 |
The 14 should be fine as I also run ah 14. If you get ah chance try your 2ch an see if that fixes it. Gt3b's are hands down the best and cheapest 3ch radio out there.
cogging with tekin 13.5t? - Similar Threads | ||||
New Tekin 13.5 cogging? | lkracer | Axial Wraith | 12 | 08-16-2012 08:16 PM |
Tekin 13.5 just cogging or bad MMP? | Checkitout0125 | Electronics | 11 | 01-17-2012 07:28 AM |
glitching and or cogging | mudn_1 | Team Losi Comp Crawler | 12 | 03-14-2011 06:00 PM |
Cogging ? | drzjohn | Team Losi Comp Crawler | 7 | 10-23-2009 10:43 AM |
What is cogging? | Deezul | Newbie General | 4 | 05-29-2008 08:25 PM |
