10-06-2012, 02:44 PM | #1 |
Pebble Pounder Join Date: Aug 2012 Location: Gadrock, Al
| Stock esc problem
Everytime i pull the trigger the light turns Red, meaning reverse, but it still goes forward, & when i push the trigger for reverse, the light turns green, but it still goes in reverse, just the esc has it swapped up, so my reverse is faster than my forward but everthing on the radio is like it should be, i pull it goes forward i push it goes backwards its just the esc, & it didnt have a problem with another esc it was fine.. anyone have any ideas? i saw the threads about the diffs being swapped from the factory is this that? i bought this wraith used so i would have thought the other guys would have noticed it.. Thanks in advance for any help
10-06-2012, 02:49 PM | #2 |
Quarry Creeper Join Date: Jun 2008 Location: the White House
| Re: Stock esc problem
You need to flip the axle diffs, common on the RTR's
10-06-2012, 06:23 PM | #3 |
I wanna be Dave Join Date: Jan 2012 Location: CANADA
Or swap motor wires!! That will be easier!
10-06-2012, 07:39 PM | #4 |
Isn't the stock motor timed or is it 0° ? The RTR's are known for the diffs being installed backwards, flipping the motor wires will just delay the inevitable. |
10-06-2012, 08:22 PM | #5 |
| Re: Stock esc problem Axial Racing - Axial AE-2 ESC Set-up and Programming 15. Apply throttle to make sure motor turns in the proper direction. To reverse the direction of the motor, switch the wires going to the motor. If you fry the stock 20T motor, they are dirt cheap: http://www.ebay.com/itm/AXIAL-20T-54...item53ecd82242 Last edited by ZippoMan; 10-06-2012 at 08:32 PM. |
10-06-2012, 08:45 PM | #6 |
I was just trying to help the guy assemble his rig properly,I never said you could not switch the wires. Didn't mean to start a debate. Good luck with your issue Dtempleton! Ron out! |
10-06-2012, 08:58 PM | #7 |
Ron I wasn't debating just providing more info. |
10-06-2012, 09:00 PM | #8 |
Cool,happy days!! |
10-07-2012, 12:52 AM | #9 |
thanks for the suggestion guys ill check it out tomorrow & see if that is the issue!
10-07-2012, 12:46 PM | #10 |
Newbie Join Date: Sep 2012 Location: BREA
if you do go the way of switching the wires you may need to reverse the channel on your control to keep it going the right way
Stock esc problem - Similar Threads | ||||
Wraith stock servo problem | crawleR07 | Axial Wraith | 11 | 09-28-2011 10:55 PM |
Stock ESC problem??? | rabbottfl | Axial SCX-10 | 3 | 02-09-2010 01:48 PM |
Full Sized Servo + Stock ESC = Problem? | rctoyguy | Losi Mini-Rock Crawler | 8 | 01-06-2010 01:31 PM |
ESC Problem or TX/RX Problem? | Greatscott | Electronics | 2 | 01-10-2009 09:23 PM |
stock yoke problem? | mattman | Axial AX-10 Scorpion | 39 | 06-21-2008 06:34 PM |
