12-15-2013, 05:18 PM | #41 |
Rock Crawler Join Date: May 2008 Location: Mansfield, PA
| Re: Del Monte's Anti-IFS Wraith
^^^Me too..... . Last edited by Trugg; 12-15-2013 at 05:36 PM. |
12-16-2013, 11:43 AM | #42 |
Quarry Creeper Join Date: Jul 2011 Location: Temecula
Home dude kicked butt again on Saturday. Got the hole shot and never looked back. https://www.youtube.com/watch?v=BIQI...6suu6TU_A#t=42 Last edited by snicklefritz; 12-16-2013 at 11:48 AM. |
12-16-2013, 12:52 PM | #43 |
Rock Crawler Join Date: Feb 2012 Location: OC
Hey Jake, how much is it to get you to stay home on the U4RC events so that i may bump up one positon to 3rd? jk Dude i missed this thread completely, you are kicking absolute ass at the track man! I mean No Survivor style.... IFS....pppssstt. blah blah. Good race! |
12-23-2013, 10:38 AM | #44 |
Y-Town Crawlers Join Date: Oct 2005 Location: Not Hesperia
| Re: Del Monte's Anti-IFS Wraith Here's a better pic of the new setup. I keep jumping back and forth between 3.5" and 4" front shocks. I love the way the truck handles with the lower front end, but it feels like it blows through travel way too fast on hard landings. I think the next step will be to make new shock mounts for the front end so I can run the 4" shocks but keep the nose lower. I've been running a hard-case 2S 5000mah battery for a long time, but lately I've been experimenting with much lighter 2S and 3S 2200mah packs. Its very tricky to find a balanced suspension setup f/r with a battery pack that is 10oz lighter than what I've been running. It looks like the truck is transferring too much weight backwards and the rear shocks ride very close to bottomed out at speed. The rear of the truck is also really light, so it turns into a pogo stick if I go to a stiffer spring. I'm curious to try out Duuuuuuuude's new adjustable link mounts once they're out. |
12-23-2013, 11:00 AM | #45 |
I wanna be Dave Join Date: Apr 2004 Location: SoCal
Where's the rest of it?????? |
12-25-2013, 10:16 AM | #46 |
Quarry Creeper Join Date: Apr 2008 Location: Carson City
What plastic wheels are those? Thanks
12-25-2013, 05:12 PM | #47 |
Quarry Creeper Join Date: Jun 2008 Location: LaPorte
Hey brother, for your bottoming out issues, try some doual spring setups, I bought cheap shox off asia tees, I think their doual spring shox are under 15 for 2 maybe cheaper, the spring spacer that sits in between the two springs fits most shox and definitely the losi shox, I got 2 sets of those and 2 sets of proline power stroke spring kits which has all the different stiffness of springs in it and u can really fine tune them that way, I have the dmg #7 koh chassis and its a heavy rig, I also run 2200mah lipo's up front, I like to use a stiffer long spring and softer short one helps with bumps at speed and you couls always cut small nitro fuel tubing in matching lengths. Put them on the shock shaft on top of the spring cup as bump stops, I use shoe goo as bump stops. It also keeps the spring retainers from poping off. Hope these ideas help some. Good luck n sweet rig bro Sent from my SGH-T889 using Tapatalk |
12-26-2013, 10:44 AM | #48 |
| Re: Del Monte's Anti-IFS Wraith |
12-30-2013, 04:42 PM | #49 |
Quarry Creeper Join Date: Aug 2013 Location: South Crawlolina
This. Wraith. Is. SICK!
12-30-2013, 07:25 PM | #50 | |
| Re: Del Monte's Anti-IFS Wraith Quote:
For the time being I've got a better setup worked out for the rear suspension. I bumped up the preload a bunch on the rear springs and added a thicker shim to my MIP bypasses. This keep the suspension controllable at slow/mid speed and helped soak up the hits better at full tilt. Now its just as stable on 3s at it was on 2s before | |
12-31-2013, 11:52 AM | #51 | |
01-16-2014, 06:57 PM | #52 |
Any updates on the rig Jake? Favorite Wraith ive seen yet Btw what body/hood is that you are running? . |
01-17-2014, 09:35 PM | #53 |
This rig is going to "hurt" people tomorrow......racers are gonna get "spanked".... Seen this rig leap walls, with my own eyes. |
03-20-2014, 08:08 PM | #54 |
The Wraith is prepped and cleaned for the U4 series finals on Saturday and the Ashley cup next weekend. These will probably be the last two races for this truck, and I have a feeling that it's just about as good as it can get now. Since my last post I've upgraded to a set of VP's new scale knuckles(highly recommended) and I've build/dialed a dual-rate spring setup (even more highly recommended). And since I'm planning on building a full tube rig for next season I thought I would see what 11lbs of stuff is going look like |
03-20-2014, 08:16 PM | #55 |
2013 2.2P Nat. Champion Join Date: Sep 2009 Location: BorderLine Crawlers Season 3 is on!
Your power to weight ratio is the bomb. Awesome frame of reference pic. A tube tank will be a big change. J |
03-20-2014, 11:35 PM | #56 | |
ULTRA CUSTOM FABRICATION Join Date: Oct 2012 Location: 801
03-20-2014, 11:41 PM | #57 | |
If your gonna use tube you can take 3 or 4 pounds off that. My car weighs 8.01 pounds with 14 oz of front knuckle weight and a 1 lb battery. | |
03-21-2014, 01:14 AM | #58 |
03-21-2014, 11:59 PM | #59 |
Newbie Join Date: Oct 2012 Location: Chas. SC
More info on the Dual rate Spring set up please
03-23-2014, 11:47 PM | #60 |
RCC Addict Join Date: Jan 2009 Location: Bend
Sorry to dig up an "old" thread. Just curious if I might be able to get a few pics showing how you had the shocks mounted front and rear after chopping the cage? I'm contemplating chopping mine, but fear the front and rear towers will be too flimsy after.
Del Monte's Anti-IFS Wraith - Similar Threads | ||||
Del Monte's '07 Falcon | Del Monte | Tamiya TLT Crawlers | 48 | 07-26-2012 07:19 PM |
Del Monte's MRC | Del Monte | Losi Mini-Rock Crawler | 18 | 04-23-2010 09:24 AM |
Del Monte's Top Banana | Del Monte | Tamiya TLT Crawlers | 99 | 10-21-2008 08:28 AM |
Del Monte's Banana Tuber | Del Monte | Tamiya TLT Crawlers | 11 | 07-27-2008 01:43 PM |
