01-14-2013, 04:53 PM | #1 |
Quarry Creeper Join Date: Nov 2008 Location: NorCal
| Collecting Parts For New Kit Build
About to finalize a couple order's and looking for a bit of input/confirmation... (piece of mind for Wraith noobie, don't wanna waste $$) Current Wish-List To Start Completion: *Axial Wraith builder's kit (PURCHASED!) *Futaba 4PL Transmitter (PURCHASED!) *Holmes Hobbies 16T Crawlmaster / BXRL ESC combo (PURCHASED!) *Robinson Racing 32p Pinion Assortment - 9T,10T,11T,12T,13T,14T (PURCHASED!) *Traxxas 32p Spur Gears - 56T,60T (PURCHASED!) *Castle Creations BEC (PURCHASED!) *ThunderPower 2250mah 45c 3s LiPo (PURCHASED!) *Hitec HS-7950TH servo (PURCHASED!) *Axial HD Beveled Gears standard front/underdrive rear (PURCHASED!) *Traxxas Aluminum Big Bore Shock's with Losi MRC Spring Assortment and Crawler Innovations Spring Cup Adaptors (PURCHASED!) *Vanquish Products 1/4" Titanium Suspension Link Set (PURCHASED!) *Vanquish Products 3/16" Titanium Steering Linkage (PURCHASED!) *BGR Trailbar Front Bumper (PURCHASED!) *BGR F&R Shock Tower's (PURCHASED!) *BGR Slider's (PURCHASED!) *Vanquish Products CVD's (PURCHASED!) *Robinson Racing Idler and Output Trans Gears (PURCHASED!) *Hot Racing Lockers F&R (PURCHASED!) *MIP Driveshafts (PURCHASED!) *RC4WD Hitman Aluminum Bead-Lock Wheel's (PURCHASED!) *Vanquish Products Stage 1 Kit (knuckles, C-hubs, and lockouts) (PURCHASED!) *Beef Tubes F&R (PURCHASED!) ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Last few item's still not purchased: *BGR KOH Sport Roof Cage * Does that sound about right for a "wish-list"? Can you think of anything I am missing? Gearing: I'd like to build this rig a bit more for crawling with a mix of trail use. I figure I could start out with the 13T C.M. (for decent top end) and just gear it way down for now while I build up my driving skill level... should I swap out to 32P 56/12? I think I have the correct spur gear figured out. Is there much difference (in quality) between various brands of pinion gears? The cost of pinion and spur gears is affordable enough for me to order a range of combo's to experiment with... any brand in particular I should stick with? Thanks in advance for your time and input Last edited by BodiBuilt; 03-22-2013 at 11:26 AM. |
01-14-2013, 05:16 PM | #2 |
RCC Addict Join Date: Feb 2005 Location: Vancouver Island B.C.
| Re: Collecting Parts For New Kit Build
What you have listed there is a SOLID base for a reliable wraith. Put some weight in the front tires before you glue the tires on and maybe think about Some better lockers for the diffs since the stock ones arent very strong. I cant comment on the motor since ive never ran one, but everything else is high quality stuff so i wouldnt change anything on your list |
01-14-2013, 05:57 PM | #3 |
Forgot to mention i have been using duratrax 32p spur gears with good success, they fit perfectly. 56/12 is a good starting point, im at 56/14 on 3s and its a good mix of speed and crawling
01-15-2013, 01:40 PM | #4 |
Thanks for your reply dittohead. I just edited my above post a bit after spending my stash on a few of the most needed items on my build list... also changed from the 7955TG servo to the 7950TH after reading the recent thread on the "ultimate steering servo" Now Im off to do more research and save up some more $$ for the next round of parts! |
01-15-2013, 01:49 PM | #5 |
Rock Crawler Join Date: Oct 2011 Location: Vertical Junkie
BIG Brushless Power.................a must!!!!!!!!!!!!
01-15-2013, 01:55 PM | #6 |
RCC Addict Join Date: Oct 2011 Location: Crawlerado
| Re: Collecting Parts For New Kit Build Disagree... It's fun, but it's not as good for clean even low end power when crawling as a brushed motor can be. It really depends on what you're doing with your wraith. If bashing is your thing, and you won't be doing much if any crawling, then by all means, go brushless. If you're into actual crawling, a tuned high end brushless combo can't compare to a tuned high end brushed combo. That's my 2 cent opinion. For crawling and light bashing, you can't go wrong with the Holmes Hobbies 27T Trailmaster Pro. I though that the low end on it wasn't going to be enough. I was DEAD WRONG. It has so much torque that if you get a tire stuck, it will flip the whole rig before it runs out of power/torque. It's a beast. I haven't had the 13T, but I have run the 45T Torquemaster Pro. My money is on the Trailmaster. It'll blow your expectations away! It's just plain awesomeness in a can motor. Last edited by TheScaleAddict; 01-15-2013 at 01:57 PM. |
01-15-2013, 01:55 PM | #7 |
| Re: Collecting Parts For New Kit Build |
01-15-2013, 02:13 PM | #8 |
Have you seen the Blue Monkey RC Titanium Links. I really like mine. Site is http://bluemonkeyrc.com |
01-15-2013, 02:39 PM | #9 |
| Re: Collecting Parts For New Kit Build Im running a decent brushless combo (tekin rspro/13.5t sensored) and its not nearly as good as a brushed setup for technical crawling, its good for horsing around and spraying your buddies with dirt/rocks |
01-15-2013, 02:51 PM | #10 |
01-15-2013, 02:56 PM | #11 |
Quarry Creeper Join Date: Oct 2011 Location: Land of earthquakes
I recommend you to use the Beef tubes for the stock plastic housings, they provide a solid attachment for the c-hub bolts plus some extra weight in the axle assembly
03-06-2013, 01:45 PM | #12 |
Just updated my original post as I have collected many of the item's on my wish list... almost there! Just about to place an RPP order to scratch a couple more goodies off the list. Do I want the R.R. 1pc Output gear or the OEM style 2pc design? No future plans to run DIG if that matters... |
03-07-2013, 02:19 PM | #13 |
Where is a "crickets chirping" smiley icon when you really need one? |
03-07-2013, 02:25 PM | #14 |
If you aren't going to run dig, then the 1 piece is the way to go. Very solid unit.
03-07-2013, 02:38 PM | #15 | |
| Re: Collecting Parts For New Kit Build Quote:
If I am reading you're sig correctly you have a full-size S10 ON 42"s!?!?! I'd like to see a pic of that! | |
03-07-2013, 02:58 PM | #16 |
Quarry Creeper Join Date: Dec 2012 Location: Cottage Grove MN
Yep get the one piece I just put mine in and love it !! |
03-07-2013, 03:33 PM | #17 |
| Re: Collecting Parts For New Kit Build Its on the old style 40" mtrs now.
03-07-2013, 08:20 PM | #18 |
i was recently at a scale comp and im pretty sure there wasnt a brushed motor in the 30 or so rigs that competed.
03-08-2013, 04:32 AM | #19 |
Pebble Pounder Join Date: Dec 2012 Location: Orlando
03-09-2013, 08:14 PM | #20 |
Collecting Parts For New Kit Build - Similar Threads | ||||
build MRC NAT3 from parts instead of buy whole kit? | dave m | Losi Mini-Rock Crawler | 11 | 02-02-2009 11:07 PM |
1.9 scale build options - Hilux kit, RC4WD kit, or piece together my own? | Nova's Ark | General Scale Talk | 8 | 06-12-2008 10:24 AM |
AX10 RTR or Kit for a build? Kit seems more popular, but RTR has some nice features. | nukexbi | Axial AX-10 Scorpion | 21 | 05-09-2008 01:27 PM |
Axial AX-10 Scorpion 1/10 Rock Crawler Kit Build, Chapter 3 Add on Parts. | JAM MaxAmps.com | Axial AX-10 Scorpion | 15 | 02-04-2008 07:49 PM |
