01-17-2013, 07:25 PM | #1 |
Newbie Join Date: Jan 2013 Location: winchester
| Novak Eiger Rockstar 55T
I installed this setup it has worked great until I moved the battery to the front. I unpluged the esc and moved to the rear and now no throttle just steering. I tried to reprogram several times no luck. I have done all the upgrades myself. It has all the aluminum upgrades . The only stock parts left is the body. Any help would be great. Thanks
01-17-2013, 07:27 PM | #2 |
Quarry Creeper Join Date: Jul 2011 Location: charlotte
| Re: Novak Eiger Rockstar 55T
did you plug the esc back into the correct channel? sounds like it..
01-17-2013, 07:31 PM | #3 |
yes, I double checked it I may order a holmes hobbie torque master and see what happens. But its only like 3 or 4 months old but oh well Thanks for the reply
01-17-2013, 07:53 PM | #4 |
Unplug the servo. I had a issue wth a bad shift servo and my Novak eiger did the same thing.
01-18-2013, 04:12 AM | #5 |
Rock Crawler Join Date: Jan 2006 Location: Bellaire, MI
Yep programming the esc has nothing to do with other servos plugged into the receiver. When you switch on the esc, it sends power to the receiver to run the servos instantly, no matter how the esc is programmed. Double check that the connector for the servo isn't plugged in backwards into the receiver as well. |
02-04-2013, 03:21 PM | #6 |
I found out I had a bad receiver. I bought a airtronics mx3 works like a champ. Just ordered hood hinge kit and forward battery plate.
Novak Eiger Rockstar 55T - Similar Threads | ||||
2-3S Brushed Motor ESC from Novak - The Eiger, and Eiger Pro. | Charlie | Electronics | 32 | 08-05-2012 08:59 PM |
Eiger Terra Claw 55T ESC Combo WONT WORK! SOLVED | Maglizard | Electronics | 1 | 07-18-2012 06:19 AM |
burnt out my novak rooster crawler today looking for some input on the novak eiger? | laxjj14 | Electronics | 5 | 05-16-2012 08:55 AM |
