02-14-2013, 10:04 PM | #1 |
Rock Stacker Join Date: Jul 2007 Location: Sanger
| Rear Steer?
Sold my Losi with rear steer and picked up a Wraith. After the buddy i sold it to brought it over today just proved how much i miss rear steer. I was looking at just doing the same RC Punk conversion that i did on my losi but ran across the TOPCAD kit. My question is, Is this kit all you would need for rear steer? It says it has a Y connector to tie in with the front servo. So im assuming that is just doesnt have a selector switch to be able to turn the rear steer off and just go front steer or cab crawl like the Punk computer allows. Sorry for the newbie question but still kinda in the learning curve of things. Axial Wraith 4WDS Conversion Set Red TopCad 23020 Here is a pic of wraith ive got now. |
02-14-2013, 10:24 PM | #2 |
Quarry Creeper Join Date: Aug 2011 Location: Antioch by a rock!
| Re: Rear Steer?
IMO you will need a 3 channel radio
02-14-2013, 10:32 PM | #3 |
| Re: Rear Steer?
Well after reading it a couple times I think I answered my own question. That kit might be the way to go to just get the c's, knuckles and axle shafts for now then upgrade the axle shafts when needed. I think I'm just gonna stick with the punk setup since I know it works.
02-15-2013, 08:32 AM | #4 |
Newbie Join Date: Dec 2012 Location: Houston
| Re: Rear Steer?
Where do they sell this "rear steer kit"? Cause I want it!
02-15-2013, 08:49 AM | #5 |
Quarry Creeper Join Date: Jun 2010 Location: lexington nc
| Re: Rear Steer?
asiatees.com sells them i was thinkin bout gettin two of them myself
02-15-2013, 09:38 AM | #6 |
Rock Crawler Join Date: Oct 2012 Location: Garden Grove
| Re: Rear Steer?
Seems like a nice kit with the CVD's included. I just bought individual parts for my setup which I haven't installed yet.
02-15-2013, 11:44 AM | #7 |
RCC Addict Join Date: Feb 2005 Location: Vancouver Island B.C.
| Re: Rear Steer?
I would strongly recommend adding a bec for each servo or get the big 20 amp castle bec. I run rearsteer and i have a bec hardwired in to each servo and the rearsteer is controlled separately on the 3rd channel. It works very well but the 7955 servos im running are struggling at times even at 7volts so i might have to upgrade to 7980s, the pitbulls really add strain to the steering.
02-15-2013, 03:40 PM | #8 |
| Re: Rear Steer? |
02-15-2013, 06:22 PM | #9 |
| Re: Rear Steer?
Well i broke my knuckles and stripped my chubs today so i went ahead and ordered that 4ws kit. it was cheaper to get the kit than it was to get the knuckles and chubs separately. so i see how well they work once i have them here and install them.
02-15-2013, 10:15 PM | #10 |
Quarry Creeper Join Date: Oct 2011 Location: Shirley
| Re: Rear Steer?
i would get a hacked flysky to control the rear steer. being able to select front, rear, or all 4 steering with normal and crab modes is pretty damn cool. had it set up on a losi with dig at one time.
02-16-2013, 08:39 AM | #11 | |
| Re: Rear Steer? Quote:
I had a rc punk computer on my losi. I just ordered this kit since I broke my knuckles. Does that fly sky kit allow you to just turn the rear and not the front? | |
02-16-2013, 12:23 PM | #12 |
Rock Stacker Join Date: Feb 2013 Location: North Texas
| Re: Rear Steer?
The Futaba 4PL is a pretty sweet radio setup with 4ws already programmed in on the third channel. It gives you the option of front/rear/normal 4ws/and crab steer at the press of a button. Plus a slide switch 4th ch for my 2spd trans
02-16-2013, 02:24 PM | #13 |
Newbie Join Date: Jan 2012 Location: Kamloops
| Re: Rear Steer? |
02-16-2013, 03:47 PM | #14 |
| Re: Rear Steer? yes, you can select front only, all 4, rear only. and toggle between crab (front and rear pointing the same direction, i.e going sideways) and no crab. (front and rear oppose, really tight turns). plus its proportional, meaning not just a full lock one direction or the other. and all at a fraction of the cost of the futaba. plus can be programmed for up to 10 seperate models.
02-17-2013, 09:17 AM | #15 | |
That's a nice radio. So do you just plug in the rear servo to one of the channels on the receiver and your good? So you wouldn't need something like the rc punk computer if you have this radio? | |
03-04-2013, 05:48 PM | #16 |
| Re: Rear Steer?
yeah, front servo into ch1, rear servo into ch3, esc is ch2 as before. there is a single push button that can be programmed for 3rd ch and 4ws on the futaba and each push of the button will put you into a different steering configuration. start out in 2ws, come to a tight turn, hit the 3rd channel button one time and your now in reverse phase(typical) 4ws. there is also an option of whether you want to be able to use all 4 steering configurations(front/reverse{typical}/same{crab}/or rear), or three (front/reverse/same) or just two(front/reverse). go to futabas web site and check out the manual for it. its 100+ pages but you dont need to read all of it. 4ws starts on page 74 and is pretty easy to set up
Rear Steer? - Similar Threads | ||||
Rear steer on rear center VP axle | irokcrawl | Axial Wraith | 5 | 09-23-2012 03:44 PM |
rear steer vs rear dig | ax10newguy | Newbie General | 14 | 06-22-2010 02:33 PM |
Rear steer lockout so you can still mount stuff on rear axle | bill400ex | Duratrax Cliff Climber | 9 | 02-16-2010 07:49 PM |
rear steer help | broncoholic | Electronics | 5 | 04-06-2007 08:05 AM |
