03-19-2013, 02:43 PM | #1 |
Rock Stacker Join Date: Sep 2012 Location: Norway
| just bought a BL system. need some advice.
So i just ordered a Traxxas Velineon bl system and i was wondering if there are any upgrades i should order right away.. Is there anything that WILL break straight of the bat? And is it the same pinion gears on the stock 20t axial motor and the traxxas velineon motor? And what gearing would you guys run on this setup? |
03-19-2013, 02:48 PM | #2 |
| Re: just bought a BL system. need some advice.
I'd gear it for torque! If you are running all stock stuff you should consider: 32 pitch pinion/spur gear Robinson Racing trans gears (idler and output) MIP drive shafts Axial HD gears Gunnar pins aluminum wheels Beef Tubes |
03-19-2013, 03:35 PM | #3 |
RCC Addict Join Date: Mar 2010 Location: Auburn, MI
Get your favorite beverage, and sit down for some reading... Choosing a motor and ESC for your Wraith - Gearing Added! |
03-19-2013, 04:45 PM | #4 |
You may also want to get the: WRAITH & AX-10 BEEFY Top Shaft WRAITH & AX-10 BEEFY Top Shaft - Super Shafty Robinson Racing 32P Slipper Kit Steel Slipper(56T) Robinson Racing 32P Slipper Kit Steel Slipper(56T) - Super Shafty WRAITH "ULTIMATE" Motor Plate WRAITH "ULTIMATE" Motor Plate - Super Shafty More parts tend to break with the power of brushless. |
03-19-2013, 04:57 PM | #5 |
I'm testing traxxas max drive shafts to transfer power to hot racing lockers sent from all metal Robinson racing tranny gears and traxxas 14 pinion duratrax 56 spur. 32p I think I'd run a 11 or 12 pinion and 56 spur with the velion(gear for minimal heat). 60 spurr probly isn't possible with max drive shafts. I don't upgrade anything unless I have to and I've had to upgrade this stuff with a very high power brush less motor that I run The duratrax plastic 32p spurr is holding up awesome. Would consider the Robinson metal spurr if I was constantly stripping sports but I'm not. Last edited by evan03; 03-19-2013 at 05:01 PM. |
03-19-2013, 05:01 PM | #6 |
If you'd like, read through the Buxom Melons link in my sig. It started with the VXL and Maxx Shafts... I've tried about every combo out there. Currently running a Pro4 3300. |
03-20-2013, 07:32 AM | #7 |
Newbie Join Date: Mar 2013 Location: Central city
Not sure if your on a tight budget or not. If you are like me I would suggest MIP drive shafts, a good high torque servo and after market steering links to start with. The rest of the truck seems fairly sturdy and does very well for a stock truck. Actually the wraith really surprised me with how capable it was out of the box with just the few parts that I mentioned added. Then replace the other parts as the wear out or break.
03-22-2013, 04:07 PM | #8 |
Can anyone tell me if this traxxas spur gear will fit on my wraith? Traxxas 3957 Spur Gear 0.8P 56T - SAMIRC And thank you so much for all the replies to my thread! Big help Got the system today and installed it Super happy with the performance Running stock gearing and its don't feel to bad but not optimal. So looking at different gearing specs |
just bought a BL system. need some advice. - Similar Threads | ||||
Just bought SCX-10 FNG needs some advice | muddy8jeep8 | Newbie General | 13 | 08-28-2013 08:33 AM |
I just bought this xr10 any advice? | 108snowbandit | Axial XR10 | 10 | 07-27-2012 06:40 PM |
a noob just bought an artr AX10 and need some advice | roosterkill | Newbie General | 20 | 08-07-2009 09:37 PM |
A little advice/point in the reight direction - Cantilever system | craigrobbo | General Crawlers | 14 | 11-02-2008 12:27 AM |
