03-24-2013, 07:21 PM | #1 |
Newbie Join Date: Feb 2013 Location: Westport, MA
| Wraith Issue
Well my wraith is only about a month old and I have my first problem. It has not seen mud or water just driving it in my back yard in the grass and rocks. What is does is when going at a steady throttle speed it will shudder. What I mean is I am holding the throttle at a steady pace and, the truck seems to lose signal for a split second at a time, it travels like I am pulling the throttle and letting it go constantly. And then it sometimes when I turn left on the control it just stays straight, it never has a problem turning right however. Both batteries are fully charged when this happens. Not sure what to do to troubleshoot. |
03-25-2013, 01:51 AM | #2 |
Newbie Join Date: May 2012 Location: Junction City
| Re: Wraith Issue
I had a similar problem with my wraith. My charger said my lipo was charged but I'd plug it into the wraith and only have half throttle and if I turn left or right I wouldn't have any power. Come to find out since my battery leads use bullet connectors to plug into the battery, I was losing voltage at those bullets. So I polished them up and my deans connectors and my power had come back. Hope this may help.
03-30-2013, 10:20 PM | #3 |
| Re: Wraith Issue
really no other ideas?
06-22-2013, 05:49 PM | #4 |
| Re: Wraith Issue
bump on this problem. I noticed that if I am driving straight forward and backwards there is no jerking or shuddering but... if I turn the acceleration seems to jerk and shudder. This doesn't happen every time but often enough that it is very annoying. |
06-22-2013, 06:30 PM | #5 |
Pebble Pounder Join Date: Dec 2011 Location: Ohio
| Re: Wraith Issue
The servo might be causing some radio interference. Traxxas 2075 servos are notorious for this same issue. Try another servo if you are able to.
Wraith Issue - Similar Threads | ||||
Wraith rear axle issue | Papacrawls | Axial Wraith | 0 | 02-13-2013 04:32 PM |
Wraith steering servo issue | wheeler chaos | Axial Wraith | 6 | 03-30-2012 03:16 AM |
Issue with new wraith, ESC, battery??? | Stainless02 | Axial Wraith | 11 | 01-16-2012 11:45 AM |
RC4WD Wraith link issue? | OSWHollowpoint | Axial Wraith | 9 | 01-11-2012 02:17 PM |
Wraith ESC/Rx issue | lcbsc | Electronics | 1 | 11-14-2011 12:16 PM |
