Thread: Battery movement
Old 03-27-2013, 12:49 PM   #1
Default Battery movement
How do i go about moving the battery to the front. Do they make a kit?
Hillbillyrcer is offline   Reply With Quote
Old 03-27-2013, 12:54 PM   #2
Default Re: Battery movement
I've never heard of such a thing.. .
throttlejock27 is offline   Reply With Quote
Old 03-27-2013, 01:00 PM   #3
No kit that I know of.
Pic a spot you want to mount & do some searching.
Underhood seems the most poular.
I have an electronics tray by Crawlspae under my hood.
What battery would be 1st question
Dostradamas is offline   Reply With Quote
Old 03-27-2013, 01:10 PM   #4
Seriously just do a search!
Old 03-27-2013, 02:19 PM   #5
Check out Crawler Innovations. They have a electronics tray and the hood pin kit.
hatefulboy is offline   Reply With Quote
Old 03-27-2013, 03:16 PM   #6
Here
Front electronics box
Old 03-27-2013, 04:18 PM   #7
Cut ur stock battery tray in half long ways and mount it in the hole behind the receiver box.
XJrob is offline   Reply With Quote
Old 03-27-2013, 07:37 PM   #8
I did the battery tray to the front on my prior Wraith and this current one I did a single piece tray in the front. I like the single tray better because it's easier to get the battery in and out.
ik632 is offline   Reply With Quote
Old 03-27-2013, 08:51 PM   #9
Originally Posted by throttlejock27 View Post
Very nice. Thanks for the info. That will be my next purchase...
does anybody know if a 5000 mah 2 cell lipo will fit? Before i start trying to round up everything i need to move it?
Do u have to remove the screws every time u take the battery out?
Where did u get it? i have searched the net and with no luck...
Old 03-27-2013, 09:11 PM   #10
It will fit, but it'll be tight!!! I have the receiver box in the passenger side floor board.
Lentsnh2012 is offline   Reply With Quote
Old 03-27-2013, 09:21 PM   #11
Here is a whole article on moving the battery up front and hinging the hood.
An Axial Crawler Blog - Get Your Axial Off The Couch And Have Some Fun
Does anybody know if a 5000 mah 2 cell lipo will fit? Before i start trying to round up everything i need to move it?
I can get a 3S 5300 mah lipo in mine without any problems.
k7zpj is offline   Reply With Quote
Old 03-28-2013, 02:16 AM   #12
Yea I get a 3s 5000 in mine also with no problems.
Old 03-28-2013, 06:56 AM   #13
No you don't have to remove any screws to get the battery out. U just unstrap it, ur able to keep ur factory Velcro straps with this set up
Old 03-28-2013, 09:29 PM   #14
I also moved my battery forward using all of the stock components,minus a couple zip ties.There is no sense in spending money on something easily done with just the tools in your tool box.I used the stock tray and some good ol fashion cut to fit ingenuity.I fit everything from a hard case 2s 5000 to a 5000 nimh under the hood,with a ton of room to spare.To me thats the best part of this awesome hobby!
redneckwraith is offline   Reply With Quote
Old 06-10-2013, 05:55 AM   #15
How do you guys solve the "easy opening hood" (with clips and what?)?
quart is offline   Reply With Quote
Old 06-10-2013, 08:16 AM   #16
I used 3/16" plastic cable clamps for the hinges and Traxxas #3727 Battery hold down plate for the posts/hairpins.
Battery movement - Similar Threads
Foward movement issues Broken40 Electronics 2 11-16-2010 01:08 PM
Movement of the axle: can autocad help ? setecastronomy Tools, and Procedures 9 06-30-2008 08:09 PM
axle movement? elkie General Crawlers 2 03-23-2006 01:59 PM
Lateral Movement in Axle Denk General Crawlers 4 02-19-2006 10:36 AM
driveshaft movement dreadshawn Traxxas Crawlers 4 10-24-2005 06:49 AM
