07-28-2013, 12:33 AM | #1 |
Quarry Creeper Join Date: Aug 2012 Location: Melbourne
| Centre transmission options?
I am currently buying the parts for my Wraith rather than buying the kit and replacing 70% of it with upgrade parts. I'm planning on running a dig on it and basically using it for crawling only. I've already bought Junfac shafts and want to get your opinions on centre tranny options... Should I buy the stock outer casing or something else that is dig compatible? What gears do you guys recommend also?? |
07-28-2013, 08:15 AM | #2 |
Quarry Creeper Join Date: Jun 2012 Location: Next to you
| Re: Centre transmission options?
It all depends on you. The scx trans works in wraith and you can put a VP dig on that or go with stock and get dig that way. Metal gears Robinson. If still looking for things look at Harley's bulletproof wraith stick that has way more info that I can even remember.
07-28-2013, 09:30 AM | #3 |
Rock Crawler Join Date: Apr 2004 Location: Not where I belong.
You can fit dig in the wraith transmission case, that's why its different than the scx.
07-28-2013, 10:53 AM | #4 |
Just Crawling: Get a stock case Add Axial Dig HR Steel gear set Stock outputs 32P 60t Spur gear 12-14t pinion gear |
07-28-2013, 11:43 AM | #5 |
I wanna be Dave Join Date: Jan 2012 Location: CANADA
It is great to have Harley's advice!! He knows his stuff!! I wish I had his resources and connections, hehehe |
07-28-2013, 01:12 PM | #6 |
Thanks everyone now I can order one!
07-28-2013, 01:42 PM | #7 |
| Re: Centre transmission options? |
07-28-2013, 04:46 PM | #8 |
Centre transmission options? - Similar Threads | ||||
transmission options | brandonwalsh420 | Large Scale Rigs | 6 | 04-11-2012 06:31 PM |
centre differential required ? | sideshowbob | Newbie General | 2 | 11-24-2011 12:40 AM |
Rock Force Transmission options | Nonsonic | Kyosho Crawlers | 4 | 06-17-2010 01:34 AM |
hi lux transmission options | 4x4wheelier | 1.9 Scale Rigs | 7 | 11-25-2008 07:08 PM |
TLT transmission options for your crawler | TLTCrawlin | Tamiya TLT Crawlers | 32 | 02-07-2007 12:34 PM |
