09-20-2013, 01:33 PM | #1 |
Newbie Join Date: Aug 2013 Location: Canada
| Spur gear
I just received my new spur and pinion for the wraith. (60/11 32p). However the spur gear seems to be universal fit. I would have to modify it to make it work. Should I? Or return it to the LHS?
09-20-2013, 02:37 PM | #2 |
Quarry Creeper Join Date: Jul 2013 Location: Maple Ridge B.C. Canada
| Re: Spur gear
Return it and buy the traxxas one it is a direct fit.
09-20-2013, 04:59 PM | #3 |
| Re: Spur gear
Kimbrough spurs fit the Axial spur adapter nicely. Kimbrough 32P Spur Gear (60T) [KIM239] | RC Cars & Trucks - A Main Hobbies |
09-20-2013, 05:48 PM | #4 |
| Re: Spur gear
Duratrax does also. That's what I'm running.
09-20-2013, 07:10 PM | #5 |
Thanks for the replies. This is what the LHS ordered in for me. I will go see them tomorrow and see if they have the correct one in stock. |
09-20-2013, 07:19 PM | #6 |
That looks like either Associated of Losi. They are meant to be used with a slipper...not spur adapter.
09-20-2013, 07:19 PM | #7 |
Rock Crawler Join Date: May 2010 Location: Bedford Ky
Like said before traxxas, kimbrough, or duratrax. I've got several of each in 32p and they all work great. I believe what you have there is a losi spur. Sent from my iPhone in the shop |
10-21-2013, 04:32 PM | #8 |
The LHS fixed me up and I'm all good now. I'm setup with a 60t spur and 11t pinion 35t motor. Works well as crawls nicely. Thanks again for all the help. |
10-31-2013, 01:52 PM | #9 |
Quarry Creeper Join Date: May 2012 Location: Baja, Mex / Calexico, Ca.
| Re: Spur gear I've always had problems to my traxxas 32p spurs to work on the wraith, 3 of them I tried were bit uncentered always, my kimbrough and my duratrax spurs were direct fit
Spur gear - Similar Threads | ||||
Which pinion gear works best with RC4WD Steel spur gear? | e32lover | HPI Wheely King | 8 | 03-10-2013 06:09 PM |
Which spur gear and pinion gear with 35t motor | vegas1973 | General Crawlers | 1 | 08-19-2012 11:42 AM |
Micro T spur and Micro Crawler spur gear. Same thing? | matts175 | Losi Micro-Rock Crawler | 4 | 10-15-2011 01:18 AM |
Wobbling spur gear....Need alum. gear hub! | sickfab | HPI Wheely King | 26 | 10-01-2007 02:09 AM |
Spur gear help | geeps | Newbie General | 2 | 01-23-2007 06:15 PM |
