10-14-2013, 03:30 AM | #1 |
Pebble Pounder Join Date: May 2013 Location: new zealand
| C-hubs coming lose
have put some alloy C-hubs on to stop the screws that hold the steering knuckles on from coming lose...now the screws holding the C-hub to the diff are working lose. anyone have any fixes for this besides just doing full alloy diffs? |
10-14-2013, 03:38 AM | #2 |
Rock Crawler Join Date: Sep 2011 Location: FNQ Australia
| Re: C-hubs coming lose
The best way is to use machine thread bolts (fine thread), not the coarse thread that comes with the kit. they never stay tight for long,. If the holes are getting a bit flogged out put a drop of CA glue on the machine screws before they go in. ( I hope the Wallabies cop another flogging in the Bledisloe on Saturday !) |
10-14-2013, 05:22 AM | #3 |
Pebble Pounder Join Date: Sep 2013 Location: Mechanicsburg, PA
I can see starting with the fine thread screws. I would question using them after using course thread screws. I don't think there would be enough material left to be secure. The CA glue is a fine tip. Just make sure your screw heads are in good condition.
10-14-2013, 05:32 AM | #4 |
Rock Crawler Join Date: Dec 2011 Location: Blacksburg
Beef tubes.
10-14-2013, 05:51 AM | #5 |
| Re: C-hubs coming lose Beef Tubes link Those look like a good long term solution if the CA glue doesn't work. I wonder if screws come with. I'll do some more reading. |
10-14-2013, 06:21 AM | #6 |
I add one click of caster past stock and drill new 2.5mm holes at the other end of the slots. Thread m3 fine thread bolts into the new holes and your done. Mine don't loosen up at all.
10-14-2013, 06:36 AM | #7 |
No screws come with Beef Tubes. Beef recommends M3x8mm or M3x10mm.
10-14-2013, 07:41 PM | #8 |
Newbie Join Date: Jun 2013 Location: Springfield
I have had the same problems, now i have to replace the knuckles as well.
10-14-2013, 08:07 PM | #9 |
Quarry Creeper Join Date: Oct 2011 Location: Land of earthquakes
Beef tubes + 3x10mm screws + blue loctite = no more loose c-hubs |
C-hubs coming lose - Similar Threads | ||||
lose that butt | Ace138 | RC4WD Bully | 7 | 11-29-2011 08:33 AM |
lose Steering | Coops | Electronics | 2 | 08-16-2011 11:29 AM |
Lose vs Loose | EvilTwin v2 | Chit Chat | 12 | 12-09-2009 07:53 PM |
Pinion come lose | Moondust1950 | Tamiya Txt-1 and Juggernaut | 14 | 12-10-2006 02:23 PM |
