10-22-2013, 12:29 PM | #1 |
Newbie Join Date: Aug 2010 Location: metro detroit area
| Driveshaft question.
Looking to upgrade my stock driveshafts and I am searching C.K.R.C.'s site and there is MIP shafts, JunFac, and C.K.R.C.'s own shafts. What ones are better/best? Don't really care about th eprice as they're all close to each other.
10-22-2013, 01:08 PM | #2 |
Quarry Creeper Join Date: Jun 2013 Location: Tacoma
| Re: Driveshaft question.
MIP is always a good pick up for drive shafts. I plan on picking up a set myself.
10-22-2013, 01:11 PM | #3 |
2013 2.2P Nat. Champion Join Date: Sep 2009 Location: BorderLine Crawlers Season 3 is on!
Go with Traxxas TMax shafts. A ton lighter, cheaper and absolutely tough as hell. Trim to fit your rig. They are awesome. J |
10-22-2013, 02:08 PM | #4 |
Newbie Join Date: Oct 2013 Location: Mountains of North Carolina
SkaldidDog- Can you explain what you mean by "trim" please? Does this require machine shop style tools or anything special?
10-22-2013, 04:10 PM | #5 |
Quarry Creeper Join Date: Aug 2009 Location: Gamecock Country
Buy some AX10(Scorpion)MIPs off of eBay for $39 and while you are at it, get Traxxas part# 5145, 1 bag of 6 for $6, they are M4 x 2mm pins(instead of M3 x 1.5 factory). $45 in all. I have been running this for a whlile and no problems with a MMP, Pro4(3300),3s setup. I crawl alot so I like the weight down low and you will never break them. I have never tried the t max drivelines, but have heard good things about them.
10-22-2013, 04:35 PM | #6 |
RCC Addict Join Date: Jul 2012 Location: Oreganastan
Traxxas # 4928x for yokes, and 4951x for sliders. Trim the slider/shaft to length (utility knife & sandpaper) The yokes have a 5mm hole with some extra material (designed for round w flats) I just drill out those flats to make the holes round (5mm drill bit & drill) The front side of the tranny with the spur is tight. I am able to slightly sand the outside of the yoke to fit an 87T 48p spur (barely) The yokes that attach to the tranny I had to remove some of the flat end to get the holes to line up on the shaft & yoke. This is the hardest part for me because you have to take enough off to keep from binding but leave as much on there as you can for strength (dremel sanding drum & sandpaper) The ends that connect to the axles needed a washer/shim to take up some slop. Cheap & easy & holding tight with 3s 35T brushed Axial tips and tricks Maxx Shafts made easy. The supplied traxxas pins work great & are beefier than the axials Last edited by Dostradamas; 10-22-2013 at 04:54 PM. |
10-22-2013, 05:39 PM | #7 |
I will pass on the Traxxas driveline stuff. Do not want to keep plastic. The way my luck is, I will break it at a most inopportune time. Steel is the way I roll when it comes to this stuff. So, like my original post.....C.K.R.C.'s, MIP's or JunFac's ?????
10-22-2013, 06:33 PM | #8 |
Pebble Pounder Join Date: Apr 2013 Location: CC
MIPs is next on my list for my build. |
10-22-2013, 09:10 PM | #9 |
MIP [/thread] All 3 of my ar60 axled rigs run them and I've yet to break anything outright. I did ruin a male end when the pin slid out part way and I, unaware of it pinned the throttle. The foff is running a rx8 pro4 4600 on 3s with not so much as a whimper from the shafts. |
10-22-2013, 09:15 PM | #10 | |
Rock Crawler Join Date: Aug 2010 Location: Esko
Sent from my SAMSUNG-SM-N900A using Tapatalk | |
10-23-2013, 09:14 AM | #11 |
Mip clearly. I am running a 60/40 chassis (FBII) so I need 2 different length shafts so MIP gets expensive quick. If money was not an issue, to me the obvious choice is MIP, you wont be disappointed. |
10-23-2013, 10:14 PM | #12 |
T max and revo shaft on my rig . No reason to run MIPS and I run about 2000 more watts of power then these diehard MIP guys. ;) Revo Tmax |
Driveshaft question. - Similar Threads | ||||
Driveshaft question | Demodude | Losi Micro-Rock Crawler | 5 | 02-18-2013 11:32 AM |
Driveshaft question. | 93 FORD BRONCO | Tools, and Procedures | 4 | 10-06-2012 07:45 AM |
Driveshaft Question | Gimp | Axial SCX-10 | 8 | 09-20-2009 07:44 PM |
Driveshaft Question | bigdodge88 | General Crawlers | 5 | 01-27-2009 02:05 PM |
driveshaft question | Hoser | Tamiya TLT Crawlers | 5 | 11-19-2006 07:45 PM |
