11-30-2013, 02:47 PM | #1 |
Newbie Join Date: Nov 2013 Location: Deer island
| Underdrive problems
I can't seem to get the underdrive gear to sit flat on the stock diff housing. I'm using axial part number ax30402 It's like the locker is too tall. Anyone got any ideas. |
11-30-2013, 03:43 PM | #2 |
Rock Stacker Join Date: May 2013 Location: Brownsburg, IN
| Re: Underdrive problems
Are you making sure that the bearings are fully seated into the housing?
11-30-2013, 04:02 PM | #3 |
There aren't any bearings on the inside? I ended up just taking it to a belt sander lol. Got it up and running but I can't tell a difference in performance yet.
11-30-2013, 08:46 PM | #4 |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
| Re: Underdrive problems Backyard engineering at it's best |
11-30-2013, 08:51 PM | #5 |
RCC Addict Join Date: Mar 2013 Location: Oklahoma City
You should notice a difference in a few days when the gears explode from incorrect install. Did you put underdrive in front and rear or just rear? It's not enough to notice a difference if you just underdrive the rear and not overdrive the front. |
11-30-2013, 09:44 PM | #6 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
pictures??
11-30-2013, 09:49 PM | #7 |
| Re: Underdrive problems |
11-30-2013, 11:45 PM | #8 |
You guys have no faith :p there's no way it can blow up, no moving parts were modified, nothing with any importance was changed. I took about .005 off of part # ax 30500 now if this thing goes boom I'll be the first to admit that I was wrong. The machining in the new gear set wasn't deep enough, it wasn't anywhere near as deep as the stock gear. If I had a exo gasket laying around I think that woulda solved the problem as well.
12-01-2013, 08:44 AM | #9 |
I've installed a hand full of these gears with no issues. I think some photos of the problem your will help everyone see the issues your having |
12-01-2013, 08:55 AM | #10 |
Underdrive problems - Similar Threads | ||||
Just went out to the track for the FIRST TIME. Problems Problems Problems | flyingrc | Non Crawler RC's | 4 | 07-23-2012 10:19 PM |
Over or underdrive? | Big Daddy | Axial SCX-10 | 15 | 12-09-2011 09:29 AM |
Underdrive pinion? | Tortuga275 | Axial AX-10 Scorpion | 3 | 11-11-2010 07:47 PM |
Problems problems problems hope it's worth it in the end | TJcreeperJEEP | Venom Creeper | 9 | 12-22-2009 04:54 PM |
