Thread: MS Racing's UnWraithed Wraith
Old 04-02-2016, 03:39 PM   #1
Default MS Racing's UnWraithed Wraith
I'm starting a new thread to point out what I am doing with my wraith. I have been wheeling full size rigs for years now and spent years before that racing snowmobiles. I spent a lot of time learning about suspensions and how they work. I also wheel with top level competitors in class 4 RcRocs and have learned a lot from them as well. As I built my full size rig, I studied a lot about link design and the use of a 4 link calculator before building the current suspension in my rig. I decided to take the same approach with this one. I intend to use all my knowledge to improve the suspension and overall performance of the wraith. Some of my ideas may seem a bit strange or way out of the box, but what fun would there be doing something boring like everyone else. I won't always show or describe exactly what I am doing, I want to leave it up to you all to think a little with me. So lets have fun and see where this goes.
for those following my last thread, some of this will be the same, I apologize. Lets hope this one doesn't get pulled off the tracks.
msrace is offline   Reply With Quote
Old 04-02-2016, 03:42 PM   #2
Default Re: MS Racing's UnWraithed Wraith
Here's what I'm starting with, the back was chopped off and some upgrades were installed.
Sent from my SM-G920V using Tapatalk
Old 04-02-2016, 03:56 PM   #3
Subscribed again
J.A.W - just another wraith &
a Bomber!
jwall046 is offline   Reply With Quote
Old 04-02-2016, 04:23 PM   #4
Specs
Motor
Tekin Roc 412 3100kv
previous
Axial 20t brushed
ESC
Castle Creations Mamba Monster X
previous
Tekin RX8 Gen2
Axial AE-5
Servo
Savox SW-1210SG
Battery
Orion Carbon Pro 4500
Trans
Axial metal gears
Axial Dig w/traxxas servo
AE 12t 48p pinion
Robinson Racing 93t 48p Spur
Axles
Axial Underdrive 43/13 ring and pinions front and rear
Axial metal diff cover
Axial universal style front axle shafts
Axial locker front
prototype MSR rear diff
Wheels
Super Shafty 2.2 Prangs orange anodized
Tires
Proline BFG KR2 2.2
previous
RC4WD TSL Boggers
Inserts
front MSR H2bb
rear MSR 2sfzr
Suspension
Shocks
Waiting patiently for Proline 5" powerstrokes
currently 120mm unknown brand 35wt oil small piston holes
MSR rear link/shock mounts
Titanium lower links front/rear
Radio
Futaba 4PX
Winch
RC4WD Warn w/ wireless remote
I'll try to keep this updated as things go
Old 04-02-2016, 04:25 PM   #5
My full size crawler sitting on 39" red label BFG'S
Old 04-02-2016, 04:32 PM   #6
I started by measuring the rig and scaling it up to enter it in my 4 link calculator. Based on the numbers, there is a lot that can be done to drastically improve the climbing ability.
Old 04-02-2016, 04:38 PM   #7
Next I spent some time changing the links to maximize stability as well as climbing performance.
Old 04-02-2016, 04:46 PM   #8
I needed to figure out a way to see if my changes were going to work as planned. I disconnected the front driveshaft and propped the front tires up on a box and added weight to the box until the rear tires could not push it across the carpet any longer. I did the same after changing everything to the new link design and I could easily push the weight that the old system could not. This tells me that the weight of the rig is now being transferred better to the rear tires, providing more traction. The next test will be real world to see if it climbs better.
Old 04-02-2016, 04:56 PM   #9
Here's the awesome Super Shafty Prangs with the new Proline KR2's
Old 04-02-2016, 05:15 PM   #10
So out to my test spot to try out the new suspension. I am not using the dig function here on these climbs. The rear diff is close but still needs a little more work.
Old 04-02-2016, 06:07 PM   #11
Old 04-02-2016, 06:36 PM   #12
And a few pics
Old 04-02-2016, 06:38 PM   #13
I had posted this pic earlier on my old thread that had a few wondering what was going on
Old 04-02-2016, 06:41 PM   #14
I was pretty happy with the rear foams for the most part but wanted them just a little stiffer. I put them in the freezer with 1 bead ring off each wheel. Ten minutes later I put the ring back on then took them out. The air inside expanded as they warmed up to room temperature giving them a little bit of air pressure.
Old 04-02-2016, 06:44 PM   #15
I was also not that happy with the boring shape of the "body" so I narrowed it up a little to give it a bit more shape.
Old 04-02-2016, 06:44 PM   #16
Old 04-02-2016, 06:49 PM   #17
Before and after
Old 04-02-2016, 06:58 PM   #18
I'm also not sure how much I like the roof on it. My 1:1 is open top too.
Old 04-02-2016, 07:01 PM   #19
As you can see in the last pics, I'm also in the middle of installing the new esc and moving everything around. I picked up some scales so I can get my weight balanced out while I'm at it.
Old 04-02-2016, 07:25 PM   #20
If I had a crawler as nice as your 1:1 I would punt my wraith off mountain and never look back
tacocat is offline   Reply With Quote
MS Racing's UnWraithed Wraith - Similar Threads
Motoworx Racing's All New 3.8 Wheel motoworx Vendors Tires and wheels 10 04-14-2016 07:16 PM
Caster racing's new rig. Werty Made General Crawlers 26 05-11-2015 11:37 AM
Motoworx Racing's new 1.9 design motoworx Vendors Tires and wheels 36 10-18-2012 06:42 PM
