04-05-2016, 07:45 PM | #41 |
Rock Stacker Join Date: May 2015 Location: Reno
| Re: MS Racing's UnWraithed Wraith
Just curious, why do you have the lower link mounts censored in that picture?
04-05-2016, 09:06 PM | #42 |
Pebble Pounder Join Date: Dec 2013 Location: central
I'm working on a better looking set of mounts. The ones on there are the first set I made. Sent from my SM-G920V using Tapatalk |
04-05-2016, 09:09 PM | #43 |
Front winch, esc, upper shock mount finished. Much better geometry and a nice solid package. Sent from my SM-G920V using Tapatalk |
04-05-2016, 11:25 PM | #44 |
Newbie Join Date: Feb 2015 Location: The middle
Sway bar I'm also a 1 to1 guy. But my buggy is stuck on the obstacles called broke sob jack stands. Last edited by scott037; 04-05-2016 at 11:27 PM. |
04-06-2016, 06:41 AM | #45 |
Newbie Join Date: Dec 2014 Location: Raleigh
Why such a low anti-squat? What will end up happening with it being that low is when you climb a steep, high traction incline, the rear will drop and your CG will go past axle centerline and cause it to roll backwards.
04-06-2016, 07:07 AM | #46 | |
Quarry Creeper Join Date: Aug 2014 Location: holland
| Re: MS Racing's UnWraithed Wraith Quote:
Otherway around, making the rear climb (+100% squat) will lift the CG. And due to fhe vertical orientation and acceleration of the rig, possibly over the rear axle and flip it backwards. Concider I'm learning before flaming | |
04-06-2016, 07:48 AM | #47 |
Weight placement is very important especially up front cause it can have a lever affect. Having the as that low will in fact drop the chassis on a climb and help bite in as opposed to just be a solid pivot point like you would get on a high as. Wouterb is on the right track. Notice I didn't go just under 100% I went way under. The problem with too high an as and it will stop digging for traction.
04-06-2016, 09:10 AM | #48 | ||
04-06-2016, 10:15 AM | #49 |
One thing to remember is your as will change throughout the travel. If you have a design that swings drastically as the suspension moves, it can actually induce more movement. When I design a suspension, I try to keep the as changes more on the minimum through the range of travel making it more consistent and more pridictable. Another thing to keep in mind is what direction the as numbers swing in relation to travel. My preference for that is based on use. In this case being a crawler I set the as to raise in bump travel and lower in droop.
04-06-2016, 10:57 AM | #50 | |
04-06-2016, 10:59 AM | #51 |
I'm using the one I got onothing pirate 4x4. I scaled up all the measurements to keep it as accurate as I could.
04-06-2016, 11:00 AM | #52 |
Don't overlook what I'm doing up front when I comes to near vertical climbs either.
04-06-2016, 11:09 AM | #53 |
| Re: MS Racing's UnWraithed Wraith I didn't see what you're doing for the front. I assume you've got low AS numbers there as well? I'll jump over to Pirate and see if I can find the version you're using. I would be really nice to see how the numbers change through suspension travel.
04-06-2016, 11:13 AM | #54 |
The first picture in post #43 says it all, well sort of. To give you an idea, my antisquat goes from 28% to 29% in three inches of bump travel.
04-06-2016, 12:16 PM | #55 |
RCC Addict Join Date: Apr 2009 Location: LA
Wow... you are quickly becoming my crawling superhero! I never realized all the math involved in creating a better crawler. Is there anywhere online I can go to learn more about this?
04-06-2016, 12:37 PM | #56 |
Lol thanks. As far as where to learn this stuff, that's a tough one, but you can start on some of the threads on pirate 4x4. It's all full size stuff, but the principles are the same. But it's tough cause you have to weed through a lot to find any valid info. I spent a few months studying suspension design before building my first one. And I've learned a lot wheeling with some very talented competitors.
04-06-2016, 01:45 PM | #57 |
| Re: MS Racing's UnWraithed Wraith Gotcha. I saw the coilover location change but couldn't tell with the links. You've done a very good job and thanks for the info
04-06-2016, 01:55 PM | #58 |
It's actually not the shocks or links, that little orange string has a whole bunch to do with it. Think cg manipulation.
04-07-2016, 01:00 AM | #59 | |
Got me as wel. Anyway, I downloaded the calculator. homework time. "...I set the AS to raise in bump travel and lower in droop..." This one is intriguing. Wondering about the link placement to accomplish this. At a bump a shorter upper (common set up) will bring the AS aft, nearer to the axle. Not 'higher' unless your AS traverses to behind the lower frame mount. Or am I loosing 'the right track' now? | |
04-07-2016, 01:09 AM | #60 |
| Re: MS Racing's UnWraithed Wraith |
MS Racing's UnWraithed Wraith - Similar Threads | ||||
Motoworx Racing's All New 3.8 Wheel | motoworx | Vendors Tires and wheels | 10 | 04-14-2016 07:16 PM |
Caster racing's new rig. | Werty Made | General Crawlers | 26 | 05-11-2015 11:37 AM |
Motoworx Racing's new 1.9 design | motoworx | Vendors Tires and wheels | 36 | 10-18-2012 06:42 PM |
