Thread: Steering servo location question
Old 12-25-2014, 04:52 PM   #1
Default Steering servo location question
Hey all,
I recently bought a used Wraith from Ebay. It had a lot of modifications already done but also included all the stock parts as well.
Going over this Wraith I noticed that the steering servo is attached to the frame of the truck rather than the front axle like I have normally seen.
There is also an kind of stabilising arm going from the frame to the axle.
Why is the server located on the frame rather than axle?
What difference does it make?
Thanks for any help!
pox67 is offline   Reply With Quote
Old 12-25-2014, 05:14 PM   #2
Default Re: Steering servo location question
google or search CMS and Panhard...this will explain it all
allanon1965 is offline   Reply With Quote
Old 12-26-2014, 07:29 PM   #3
If you have this.
Axial Wraith Chassis Mounted Servo - Vanquish Products
You need this for it to work correct.
Wraith Panhard Kit - Vanquish Products
Reddog95 is offline   Reply With Quote
Old 12-26-2014, 07:38 PM   #4
sounds like ya have the parts right. Thats called a chassis mount servo (CMS) and pan hard kit. the pan hard being the link bar from chassis to axle that you spoke of. Its just different way of mounting the servo to make it have more scale appearance. But there are pan hard setups in the 1:1 world. but as said above hit google up or forum search cms and pan hard under the wraith section and you'll find tons of info.
JDIRCC is offline   Reply With Quote
Old 12-27-2014, 02:39 AM   #5
Awesome, thanks guys.
I just thought it might be a set up specifically for crawling or for bashing.
Now I have the right terms (CMS, panhard) I found lots of info!
Steering servo location question - Similar Threads
Steering / Servo Question SoCal_80 Axial Wraith 2 05-24-2012 07:01 PM
best way for frame mounted steering servo location? RNUOVR General Scale Talk 3 01-11-2012 11:05 AM
Steering Servo Location.... Tydl Axial AX-10 Scorpion 1 01-20-2009 06:23 AM
(question) broke servo mount location on axle casing Hardrockguitar1 Newbie General 8 10-31-2006 03:33 PM
Alternative steering servo location AYKBOBCAT Tamiya Txt-1 and Juggernaut 12 03-20-2006 04:19 AM
