02-06-2014, 06:45 PM | #1 |
Pebble Pounder Join Date: Jun 2009 Location: Selah
| Got a couple questions
So my wraith has a hh brxl esc, cc bec, 35t brood motor and 32p 54/14 gears. My question is that ever since I started building this rig I've been battle burning up motors on 3s lipos but not on a 2s. I'm wondering if any one else has had this problem and what they did to fix it or what motor can handle constant 3s power. I have been searching but haven't gotten exact answers I need thanks!!
02-06-2014, 06:59 PM | #2 |
| Re: Got a couple questions
you are geared way too high for 3S you need to go to at least a 10t pinion if your are going to use that 54t spur...not sure if it will reach. you may hae to go to a 56t spur and a 10t pinion. I would try to stay at a minimum of 5.5 to 1 ratio...5.6 would be great with a 3S setup on a 35t motor. but thats why you are burning up motors...gearing way to high |
02-06-2014, 07:12 PM | #3 |
Ok cool that helps will it still have decent speed and torgue? Thinking about a new motor I'm more into scale crawling and bashing
02-06-2014, 07:50 PM | #4 |
Mine has good speed and excellent torque...on holmes hobbies 27t torque master sport 540 and a holmes hobbies torque master pro 540 30t...
02-06-2014, 08:26 PM | #5 |
Awesome thanks for the quick answers
02-06-2014, 10:15 PM | #6 |
Quarry Creeper Join Date: Jun 2013 Location: South jersey
Volt up and gear down! It will keep wheel speed with the higher voltage from 3s and crawl really nice from the lower ratio. Not to mention it will be easy on your pocket when you stop having to buy new motors.
02-15-2014, 10:20 PM | #7 |
regeared to a 56t spur and 10t pinion and got a Holmes hobbies torque master 27turn.power, torque and wheel speed is awesome. motor stays a lot cooler on my 3s
02-15-2014, 10:24 PM | #8 |
I run 56/14 on 3s 2200kv. Works awesome and runs cool. Awesome 56/10 should run really smooth Last edited by evan03; 02-15-2014 at 10:28 PM. |
02-15-2014, 10:26 PM | #9 |
| Re: Got a couple questions |
02-16-2014, 09:45 AM | #10 |
Newbie Join Date: Oct 2013 Location: North jersey
I'm running a 4 to 1 ratio pinion and spur with the rc4wd 2 speed trans and a 3400 kV brush less 4pole sensored motor. Truck is a missile in 2nd gear and crawls great in 1st. I am running on 3s also. Motor barely gets warm. I'm actually gonna re gear for less speed and smoother crawling / more torque. Having the option of 1st or 2nd gear is so awesome.
Got a couple questions - Similar Threads | ||||
Couple Questions | mhuffman_81 | Electronics | 1 | 09-01-2012 12:35 AM |
A couple questions | .CAL.Photo. | Axial AX-10 Scorpion | 3 | 10-10-2008 03:14 PM |
Couple questions. | i c u in my rear view | Axial AX-10 Scorpion | 5 | 05-27-2008 01:59 AM |
couple questions | jatoisthematto | Tamiya TLT Crawlers | 3 | 01-31-2008 05:37 PM |
Couple questions | BJoe | HPI Wheely King | 5 | 05-13-2007 08:16 PM |
