03-11-2014, 03:24 PM | #1 |
Newbie Join Date: Feb 2014 Location: Milton Keynes, England
| Slipping clutch???
Hi folks, My Wraith is still very new, as am I to this side of RC.... I seem to have a problem with the clutch.... Every time it gets in a tight spot, the clutch just spins up! I am sure I have done a good job building it.... I mean, it's hardly difficult but I did notice some lacking detail in the instructions particularly on setting the clutch.... Right now, its set with the end on the thread just proud of the nut. Should I leave it as it is? or, can I tweak it??? Many thanks, Dave. |
03-11-2014, 03:26 PM | #2 |
| Re: Slipping clutch???
Crank it right down as tight as you can. It'll still slip when you bind it hard but the other 98% of the time you won't even know you have a slipper clutch.
03-11-2014, 03:57 PM | #3 |
Quarry Creeper Join Date: Nov 2011 Location: Vacaville
Standard practice seems to be full tight then loosen 1/4 turn. Seems to work well for me ~Chip |
03-11-2014, 04:19 PM | #4 |
Thanks guy! I'll go with that and see how it works out!
Slipping clutch??? - Similar Threads | ||||
Slipper clutch slipping? Can't figure it out | milestone | RC4WD Trail Finder 2 | 4 | 05-12-2013 02:12 PM |
something is slipping | pugs2300 | Losi Mini-Rock Crawler | 6 | 01-11-2012 09:30 AM |
Slipping? | Carolina Crawler | Losi Mini-Rock Crawler | 21 | 10-27-2010 06:09 PM |
transmission slipping?????? | bmxcrawler | Axial AX-10 Scorpion | 20 | 12-08-2008 05:44 PM |
Rear slipping?? | jeepmann | General Crawlers | 3 | 04-18-2006 10:12 AM |
