03-19-2014, 08:04 PM | #21 |
| Re: Harley's Wraith Moonbuggy
Looking at shocks today, I think I'm going to go with the RC4WD 110mm Ultimate Scale shocks. I believe I have 2 but I'll likely try and find a full set. Seems like I've seen people sell them pretty cheap in the past so I'm guessing the Wanted section will probably pay off. I'm mainly concerned about the diameter of the body. They are probably as close as it's going to get to what I need. |
03-20-2014, 04:45 AM | #22 |
Newbie Join Date: Jul 2013 Location: Moranbah, AUST
What an interesting build. Will be watching.
03-20-2014, 07:52 AM | #23 |
Rock Crawler Join Date: Jun 2013 Location: Knox, IN
So Harley, are you doing a voder series on this build as well?
03-20-2014, 08:06 AM | #24 |
| Re: Harley's Wraith Moonbuggy |
03-20-2014, 08:15 AM | #25 |
Oh boy, those shocks make me cringe. Micro-sized pistions really limit damping, especially on a 2.2 rig, unless you are going to run 2 at each corner. The e-clips that hold the micro pistions on can pop off after repeated droop-out over-extensions. Running limiting straps can help to keep that from happening. They will also need the orings replaced and the shock shaft polished. In short, they do look good. Edit, well on second thought, if this rig is going to be a slower crawler, you might be ok with them.
03-20-2014, 08:32 AM | #26 | |
| Re: Harley's Wraith Moonbuggy Quote:
03-20-2014, 10:48 AM | #27 |
RCC Addict Join Date: Jan 2010 Location: Vermont
To echo what Shane said... Those shocks truly do suck at actually performing like a shock. On a low speed (scale) tech crawler with a drop of lube in the body they are fine. Anything above 5mph... not so good. But it sounds like you already know that. They do look awesome, just wished they were machined better. Even my Kings are starting to get suspect... |
03-20-2014, 11:06 AM | #28 |
Since VP has limiting straps out now, I think those would help from busting the micro pistions if the shock drooped out too hard. Just thinking out loud here. I think the only time I did bust the pistions was from jumping the 8lbs KOH Scrambler around.
03-20-2014, 12:07 PM | #29 |
| Re: Harley's Wraith Moonbuggy No limiting straps for this one. They aren't on the fullsize. |
03-20-2014, 12:26 PM | #30 | |
03-20-2014, 10:04 PM | #31 |
I got some more work done tonight, not a ton but at least I was able to mock it up. The drivetrain is flipped right now, I want the pumpkins on the other side and spur gear to the rear. |
03-21-2014, 02:42 PM | #32 |
Newbie Join Date: Dec 2013 Location: P-town
Man you whipped that out fast! Looks great. Love the cab
03-21-2014, 10:26 PM | #33 |
There's something about the offset cab that makes me love these rigs. This drivetrain is from a different truck but when I get the final axles in the truck and flipped over I hope to get the servo slammed down onto the long side tube. I'd like to get the servo turned around and cut down into the tube if possible. |
03-21-2014, 11:38 PM | #34 |
Sweet chassis, I like that you're building it to be scale with AR60's they are a much better choice all around than ax/scx axles ever were. I dremeled a flat in the top of a housing and cut into the pumpkin a bit which lined up the servo ear with the hole for the truss screw. The other end of the servo had a piece of delrin I drilled and ran a screw through a plate that mounted the upper links. Here's a craptastic pic of my hackery of days gone by. |
03-27-2014, 08:17 PM | #35 |
Rock Stacker Join Date: Nov 2013 Location: San Diego
Any updates with this rig Harley?
03-27-2014, 10:10 PM | #36 | |
Pebble Pounder Join Date: Sep 2013 Location: Fall River
Pretty sure these shocks are made to run with leaf springs , ( ultimate scale shock ) this is why they very lightly sprung I think .. Sent from my iPad using Tapatalk | |
03-27-2014, 11:48 PM | #37 |
03-28-2014, 08:28 AM | #38 |
Hey bud you ever finish doing that cage / chassis for you ps wraith ? Pics? Sent from my iPad using Tapatalk |
03-28-2014, 08:14 PM | #39 | |
Remember, slow. | |
03-28-2014, 10:22 PM | #40 | |
K but they would not work on my honcho ( honcho to heavy , not stock ) and this moon buggy is made out is steel no ? The springs inside of the ultimate scale shocks look like the spring from a pen haha ... I even ordered a spring set rc4wd had and they were just as soft... If ur truck is light these will work I guess... But they would pretty much just sink down to nothing with just weight of my honcho ... My 2cents anyway Sent from my iPhone using Tapatalk | |
Harley's Wraith Moonbuggy - Similar Threads | ||||
Harley's Guide to a Bulletproof Wraith | Harley | Axial Wraith | 376 | 12-02-2021 05:07 PM |
Harley's Wraith #2 - Built for Vanquish | Harley | Axial Wraith | 66 | 11-05-2012 06:17 PM |
Harley's Wraith Sportsman | Harley | Axial Wraith | 123 | 01-21-2012 05:35 PM |
Harley's Urban Moonbuggy - T1e | Harley | Axial AX-10 Scorpion | 81 | 11-20-2010 03:22 AM |
