04-03-2014, 09:19 PM | #1 |
Newbie Join Date: Sep 2013 Location: kelso
| bevel gear oblivion!
Pro 4 with mmp. 2 and 3 cell. Drag brake set at 75%. RR tranny. Mip drivelines. Beef tubes. HR lockers. Axial cvds. Axial hardened bevel gears. This wraith is eating bevel gear sets at a rate of one set per month. It also wallows out lockers and rounds the cvd drive ends to create tons of slop on the front. This is getting expensive. Is there a more bulletproof bevel gear/locker/cvd combo i should be running? It eats both front and back bevel sets. Don't really care about cost if it works. Anything would be cheaper than this. Thanks. |
04-03-2014, 09:27 PM | #2 |
Rock Crawler Join Date: May 2012 Location: Minneapolis
| Re: bevel gear oblivion!
When I read the title of your thread I thought it'd be just the pinion bearings causing it. However the multitude of issues your having is interesting. First thing is start with is a pair of dlux wraith housings. These have a huge inner bearing to handle the big power. This should save the pinion and bevel. As far as the other components. I have to ask if you think the gear mesh is good and you have it shimmed properly? As always some pics of the wear and damage would be helpful. Dna |
04-03-2014, 09:28 PM | #3 |
RCC Addict Join Date: Oct 2012 Location: Charleston South Carolina
Have you tried shimming the pinion or putting bushings on the pinion? If you want a no slop locker, Locked Up RC is the best you can buy. |
04-03-2014, 10:15 PM | #4 | |
| Re: bevel gear oblivion! Quote:
04-03-2014, 10:16 PM | #5 |
| Re: bevel gear oblivion! |
04-03-2014, 10:19 PM | #6 | |
04-03-2014, 10:26 PM | #7 |
RCC Addict Join Date: Jun 2006 Location: IN THE PIT !!
| Re: bevel gear oblivion! pro 4 HD 3/4 cell been running this for some time now - no shimming needed. ring & pinion still looks new ! this should take of your problems http://www.rccrawler.com/forum/axles...aring-mod.html |
04-03-2014, 10:29 PM | #8 |
with bigger power comes more attention to details like proper shimming and heavier duty/larger bearings etc...I would be curious as to the wear pattern on the gear teeth..maybe they are not engaging far enough into each other..
04-04-2014, 12:13 AM | #9 | |
04-04-2014, 12:16 AM | #10 | |
04-04-2014, 12:32 AM | #11 | ||||
Yes. Quote:
Erik DLux has a thread about this, stock or UD looks to be best tooth engagement and use the HD version of gears. | ||||
04-04-2014, 10:33 AM | #12 |
04-04-2014, 10:35 AM | #13 |
| Re: bevel gear oblivion! Erik drills out the bearing pockets to accommodate a much larger bearing that can handle the power and torque. Same goes for his knuckles. Check out his vendor thread on them in the vendor section. http://www.rccrawler.com/forum/axles...aring-mod.html Last edited by Lentsnh2012; 04-04-2014 at 10:45 AM. |
04-04-2014, 11:56 AM | #14 | |
04-04-2014, 12:50 PM | #15 |
Pebble Pounder Join Date: Feb 2013 Location: Mid Missouri
Does anyone have a how to link on shimming? (Mainly what pieces people are using to do it, I get why & how, just not sure where to get the shims, short of whittling them out of bulk shim stock)
04-04-2014, 01:36 PM | #16 |
| Re: bevel gear oblivion! I use nitro clutch shims. Any commonly available shim of the correct size will work though. Shimming and replacing the inner pinion bearing with a bushing makes a huge difference in strength.
04-04-2014, 01:39 PM | #17 |
I assume everyone's just shimming the pinion depth? Seems some mild machining would be required for carrier / locker side shimming. Thanks for link, got me pointed in the right direction. |
04-04-2014, 07:51 PM | #18 | |
You shouldn't need to modify the spool; you wont/shouldn't be shimming that far in. Probably 1-3 0.1mm shims should get you closer to a better wear pattern. | |
04-04-2014, 08:08 PM | #19 |
I'm kinda OCD, so I will spend quite a bit of time finding the right combination of pinion depth and carrier offset that results in the perfect mesh. Ideally you want to reduce the gears backlash to as little as possible, but not all the way to zero. The pinion shaft requires 5x7x.1mm shims. HPI part# Z852 The carrier bearings can have 10x12x.1 shims (Durango part# TD310033) placed between the carrier bearings and the ring gear or diff housings without any machine work. I don't like the stock paper gasket, so I substitute an extra shim for it. I've found that there is quite a bit of tolerance on the width of the carrier bearing mounting bosses in the plastic Axial housings, requiring anywhere from one to four shims to be added. The old Blitz rear hub carriers have small, 1.45mm wide IIRC, spacer that works perfectly as a solid pinion spacer between the pinion bearings. If your crafty, and can find some thin-walled aluminum/steel tube, you could make your own. I just happen to have lots of Blitz parts. NOTE: the spacer included with the newer blitz hubs that take the 5x11 bearings comes with a thicker spacer that won't work. Once you have your gear mesh/pinion depth set you add shims outside the housing before installing the driveshaft to remove all in/out play. Taking out the last bit of play here helps force the pinion bearings to share the load. |
04-05-2014, 09:41 AM | #20 | |
Pebble Pounder Join Date: Jan 2013 Location: DENVER
bevel gear oblivion! - Similar Threads | ||||
Bad Mesh on bevel gear and diff gear out of the box? | Elliott000 | Axial SCX-10 | 3 | 08-19-2011 06:37 PM |
worm gear vs bevel gear? | fennex | Newbie General | 0 | 11-05-2010 06:57 AM |
bevel gear, ring gear mesh | rocksteadily | Tamiya TLT Crawlers | 5 | 05-09-2009 12:04 AM |
