Thread: Knuckle Busters 1.9 Wraith
Old 02-10-2015, 01:16 PM   #81
Default Re: Knuckle Busters 1.9 Wraith
I really thought I did order the shorter ones..MIP10145.
Either way, I'm going to try this slash male end from MIP. I saw someone else on here use it for an ultra4 build. Seem to work out for them.
KBR97 is offline   Reply With Quote
Old 02-12-2015, 06:29 PM   #82
Just for anyone else who is building a 1.9 wraith. The slash male end works perfect if you need a short MIP. I almost bought a $30 dig shaft before finding these.
Old 02-20-2015, 05:41 PM   #83
Ordered some Crawler Innovations foams for the Rockbeast tires.
Also got a bunch of titanium links that closely match the length of my existing ones. These should be a nice upgrade over the all-thread ones.
Comparison shot. CI foams left, pit bulls right.
Lunsford titanium links..
Old 02-28-2015, 07:10 PM   #84
Gmade piggies, assembled and installed.
Old 02-28-2015, 07:40 PM   #85
I just ordered some of those piggybacks a few hours ago. What do you think of the factory springs on them?
Sevastra is offline   Reply With Quote
Old 02-28-2015, 09:41 PM   #86
I think they are a little too firm. But I'll know better once all the snow around here melts and I can actually get some good RC wheeling time lol. But yea first impressions...maybe a little on the stiff side.
Old 02-28-2015, 09:58 PM   #87
Trailing arms must make a huge difference in stiffness because I'm wanting something stiffer on mine. lol
fr8cture is offline   Reply With Quote
Old 03-02-2015, 09:27 AM   #88
The only thing I have for comparison is my beat up leaking wraith shock/springs so that's probably why lol. I guess I shouldn't say they are TOO firm.
Anyone have any tips for getting better articulation out of a 1.9 wraith? It's probably due to the shorter links up front. Any ideas?
Old 03-02-2015, 11:17 AM   #89
Might check and see if the balls on the shock ends are maxing out and preventing further articulation. Had that happen to me once, and came up with a creative fix for it using a couple rod ends.
Old 03-02-2015, 11:52 AM   #90
Default Knuckle Busters 1.9 Wraith
For articulation, trailing arms in the rear and a droop kit in the front that will allow you to use a longer shock. The way your shocks are vertical limits your travel to just the shock stroke. You can try angling your shocks back at the top on the front.
DTB1 is offline   Reply With Quote
Old 03-02-2015, 12:35 PM   #91
100mm Kings limited with .25" bumpstops in the bottom. I have plenty of flex even with my very short front end links
I have trailing arms in the rear but they are bumpstopped as well. Crazy amounts of flex is unnecessary in my opinion.
Pull your front shocks off and check the front end for binding. When the links get short the angles on the link ends tend to max out and bind, limiting travel movement
gottorque is offline   Reply With Quote
Old 03-09-2015, 09:36 PM   #92
How short are your front links?
Old 03-09-2015, 09:40 PM   #93
60mm Axial posts with the bent XR10 ends so they dont bind at all
Old 03-09-2015, 09:50 PM   #94
Thanks for the info. I've checked everything out and I don't seem to have any binding. The suspension flexes well, I think I'm just comparing it to a 2.2 wraith suspension which obviously has a bit more.
Finally a sunny 50 degree day that melted almost all the snow!
Old 03-23-2015, 11:11 AM   #95
Got some running today with the Wraith. Just sharing some pics and video.
Old 03-23-2015, 11:14 AM   #96
Default I have no idea how to properly embed video lol
https://www.youtube.com/watch?v=W_Tt...3SmOYm7Vyy2Psg
https://www.youtube.com/watch?v=xj89...3SmOYm7Vyy2Psg
I need to stay out of the local skate park. I got a little throttle happy and broke the front bumper supports landing nose down off a ramp.
Old 03-25-2015, 02:01 PM   #97
Somebody school me on lipo C ratings. What does it mean. What am I gaining? What are the pros and cons of higher/lower c rating?
I have been using these that I had from a RC helicopter...
I just bought one of these to try out, 60-120c ....
Old 03-25-2015, 02:16 PM   #98
The higher C gives you more punch.
Old 03-25-2015, 02:38 PM   #99
Thats what I figured. I'll assume more punch = a little less run time.
Going from 30c to the new battery I should expect to see a good jump in performance then. Nice...maybe I'll be pulling some wheels off the ground, lol.
Old 03-25-2015, 02:44 PM   #100
I have that same battery somehow I killed it. Hope it works out for ya. Turnigy is hit and miss but for the price worth the risk imo.
Knuckle Busters 1.9 Wraith - Similar Threads
Knuckle weights for wraith? Subytuner Axial Wraith 24 03-10-2015 02:46 PM
Wraith knuckle question Dhallmark Axial XR10 8 01-28-2014 05:12 PM
