06-30-2014, 07:04 AM | #1 |
Quarry Creeper Join Date: Dec 2013 Location: Central IL
| What's up with this tire
I have 2 of these tsls on my wraith doing the same thing. They're like flat? What causes this and what fixes it? |
06-30-2014, 07:10 AM | #2 |
| Re: What's up with this tire
A bead is screwed up or there is a hole somewhere that is letting air in but not out when the tire gets compressed.
06-30-2014, 07:33 AM | #3 |
Did you vent your wheel or tire properly?
06-30-2014, 07:56 AM | #4 |
The beads are goodin sure. I never did anything to them but mount them up. How do you vent then properly?
06-30-2014, 08:22 AM | #5 |
| Re: What's up with this tire |
06-30-2014, 09:13 AM | #6 |
Ok. Is 3 small holes sufficient in the treads per wheel then? Thanks Harley
06-30-2014, 11:34 AM | #7 |
06-30-2014, 01:55 PM | #8 |
If you don't run in water and don't mind drilling in the wheels, I always drill a 1/16" hole in the rim so it can breathe but you can still drive in shallow water or mud and not get the foams wet.
06-30-2014, 03:49 PM | #9 |
Newbie Join Date: Apr 2014 Location: Pocatello
Yes... Agreed with above. This happened to me once but it was cause my foams were frozen?
06-30-2014, 04:19 PM | #10 |
| Re: What's up with this tire I often drive in water. Holes in the tires are not much of an issue and water comes out pretty easy. Holes in your wheel trap water in when it does get in there.
06-30-2014, 06:58 PM | #11 |
Agreed. My point was simply that I prefer to vent the rims if water isn't an issue. I've torn enough tires already so I'd rather not make more holes myself.
06-30-2014, 07:09 PM | #12 |
Moderator Join Date: Jan 2004 Location: chicago
i poke a hot soldering iron through my tires to vent them. havent had a tear yet.
06-30-2014, 07:12 PM | #13 |
I wanna be Dave Join Date: Feb 2007 Location: BFE, NV
I vent the tires in the tread voids with a leather punch. I have never had one rip or tear.
06-30-2014, 08:46 PM | #14 |
I was going to suggest a hole punch to. If cheap plastic wheels I'd drill them. If I ran Harleys wheels I sure wouldn't touch them. I prefer to not vent with a 6 - lb rig. I have a rock bouncer style of driving and rig but still do better then holding it's own on non vented rubber with foam and me Mery foam. I bet your getting the flat tire because you have a slight rip or two in the sidewall somewhere. When the tire compresses the tear opens and Letts out air as the foam compresses then it rebounds and the tear seals not allowing air to come back in. |
07-02-2014, 10:03 AM | #15 |
Yep - Problem solves. I vented all 4 in the tire with a small hole punch. MUCH better all around performance. Thanks guys!
What's up with this tire - Similar Threads | ||||
tire poll...im gonna let rcc vote my next tire | gsrcivic | Tires and Wheels | 57 | 10-22-2013 07:05 PM |
what makes a 2.2 tire a COMP tire | durrty | Tires and Wheels | 11 | 12-30-2010 07:52 AM |
Pin Tire with Comp Tire Sidewall - How To Write up | Kraqa | Tires and Wheels | 16 | 08-27-2010 11:55 PM |
high lift tire and hummer tire comparison | luis | Tires and Wheels | 2 | 01-11-2008 06:56 PM |
Axial 2.2 Rock Lizards Tire, tire test | rockwerks | Tires and Wheels | 1 | 05-27-2007 03:02 PM |
