Thread: making a wraith bigger?
Old 10-04-2014, 09:42 AM   #1
Default making a wraith bigger?
So I have seen people put bigger tires on a wraith with the stock wheel base, and it looks funny. I am supposed to be getting a used wraith in the mail either today or tomorrow. I was thinking about trying to up the size. get bigger tires and extend the wheel base front and back maybe 1/2 inch each way. I would probably need to get a different motor, and beef everything up. anyone see this done before? I like the idea of a bigger crawler like 1/8 scale or bigger.
ben10 is offline   Reply With Quote
Old 10-04-2014, 10:20 AM   #2
Default Re: making a wraith bigger?
i exstended mine about 3/4" with suspension links. i also use traxxas tmax shafts and cut them to the lenght i need. i think a 1" about 1.5 is the max i exstend the overall wheelbase.
ground clearance will suffer the longer she is
evan03 is offline   Reply With Quote
Old 10-04-2014, 10:40 AM   #3
thats where bigger tires come into play. I think my main goal is to get over bigger obstacles. an inch and a half would be about right, then maybe 1-2 inch bigger tires and maybe widen the stance a bit.
Old 10-04-2014, 07:36 PM   #4
Tall tires on a wide offset give away they're height advantage to shorter tires on narrow offset.
Tall tires on a narrow offset have a huge height advantage.
Old 10-05-2014, 08:30 AM   #5
I like the idea of scaling it up. I want to be able to conquer bigger obsticles. Longer wheel base means I can make it up taller ledges and same with bigger tires. Out where I'm from there are a lot of big obsticles.
Old 10-05-2014, 03:04 PM   #6
Here is how I'm making mine bigger.
Cherokee Chief is offline   Reply With Quote
Old 10-06-2014, 05:13 PM   #7
Shit man that's bad ass, you need some 57" michelins.
What coil overs are those.
Old 10-06-2014, 07:18 PM   #8
Hahaha yeah I'm working on one of those. I have a ranger on 1 tons. But 1:1 is waaaaaay more expensive. I have more in my axles than most people have in their rc cars.
Old 10-08-2014, 02:45 PM   #9
home made coilovers. I took a big rig shock and welded a plate to the bottom and installed 2 springs then anoher plate on top and then a hiem joint
Old 10-09-2014, 11:03 AM   #10
Natedog's Avatar
Axial Racing - The playground just got a lot smaller
Old 10-09-2014, 02:44 PM   #11
What did that cost you. I'm debating a 1/4 eliptical rear because I can't afford coil over s.
Old 10-09-2014, 05:21 PM   #12
shocks were 40.00ea X 4, springs were 50.00ea X 8, made my own plates out of 3/8 plate I had
hiem joints 20.00 for 4
Old 10-09-2014, 05:30 PM   #13
Hmmmm maybe you could post some photos . That is with in my grasp. I only need to build two for now.
Old 10-10-2014, 04:12 PM   #14
these are the bottom plate and top plate
bottom plate welded to the bottom of the shock
cut the top smaller bolt off and welded a larger bolt on for the hiem joint
the top plate on the bolt then the hiem gets tightened down locking the springs in place
sorry no picture of the hiem installed but you can imaging that.
making a wraith bigger? - Similar Threads
bigger than 2.2 klampykixx Large Scale Rigs 51 07-19-2014 08:04 PM
Making custom c hubs for the wraith. The Misfit Axial Wraith 12 01-20-2012 05:15 PM
2.2 or bigger? fstrnu Tamiya Clod Buster 7 12-28-2009 09:27 AM
need to go bigger ax-10 victor Axial AX-10 Scorpion 23 02-07-2009 12:59 AM
