12-22-2014, 08:08 PM | #1 |
Newbie Join Date: Dec 2014 Location: 'merica
| how does the stock rear axle handle power?
I wanting to build a custom rig and just wondering how does the rear axle handle power? Such as like the gears and stuff? It will just be 2s power but on a heavy truck. Also, is the wraith rear axle the same as the yeti? On ebay most axle say front/rear, are they the same/reversible?
12-22-2014, 08:26 PM | #2 |
Rock Crawler Join Date: Jun 2012 Location: jville
| Re: how does the stock rear axle handle power?
Hd gears good spool or locker and creeperbob ti rear shafts vp lockouts and a nice diff cover ull have to have more power than 2s to break lol
12-22-2014, 08:34 PM | #3 |
But how is the STOCK axle?
12-22-2014, 10:12 PM | #4 |
Rock Crawler Join Date: Nov 2014 Location: Grimcity, On
2s on brushless or brushed? If you aren't sure, refer to Harley's motor/ESC guide. Otherwise as mentioned the HD gears are a good bet.
12-22-2014, 10:37 PM | #5 |
Quarry Creeper Join Date: Sep 2009 Location: Las Vegas
It works just fine! I ran my wraith on 4s brushless for around 10 packs and the rear axle was not one of the things that broke. Needs nothing out of the box and replace stuff if it lets loose. Best of luck Edit, and yeah the yeti axle is the same thing |
12-22-2014, 10:44 PM | #6 | |
Rock Crawler Join Date: May 2012 Location: Minneapolis
| Re: how does the stock rear axle handle power? Quote:
If you are going to run big power. You absolutely need a dlux housing, HD gear set, and locker spool (either hot racing or fi or...). I'd stay with the stock axle shafts. Titanium is more prone to brittle fracture, where the stock steel ones will twist a little before they break (I know this only as I've broken a creeper bob titanium shaft and have yet to break a stock steel one). Yes the yeti and wraith have the same rear axle. The reason wraith axles are listed as font and back is due to the hubs/knuckles vs lockouts. The other unique part is the upper link mount. If the pumpkin is on a different side than what you want you may need a different upper link to make it all work. Good luck | |
12-23-2014, 12:01 PM | #7 |
I've found the axle to be tuff even when abused with 1/8 scale power
12-23-2014, 12:53 PM | #8 | |
12-23-2014, 06:46 PM | #9 | |
As for what it takes to make it hold up. You will likely need a new locker quickly, but from there it won't need much right away. | |
12-24-2014, 06:16 PM | #10 |
Quarry Creeper Join Date: Apr 2014 Location: a land bereft of rocks
I ran a stock rear axle with a roc412 3100kv on 2S for a couple months of heavy use and it held up fine. The only damage was one of the screws holding the diff housing to the ring gear broke. Which I didn't notice until I swapped it out anyways don't worry about breaking anything until it does. I've been running the same stock pinion bearings for a year easily 2-300 packs (2 and 3s) so you probably won't need a deluxe housing either. Ymmv though but don't listen to everyone telling you to upgrade right away.
12-24-2014, 06:47 PM | #11 |
Agreed, on 2s and brushed you're good to go for awhile. And as was mentioned the locker will probably start spinning in the diff case before anything else.
12-29-2014, 05:22 PM | #12 |
I agree with harley a locked up rc spool or hot racing spool and then abuse the shit out of it. But don't forget to abuse the stock locker first as you may get a ton of run time out 9f it before needing upgraded. |
how does the stock rear axle handle power? - Similar Threads | ||||
Only the rear axle turns under power? | theshackle | Axial AX10 2nd-gen | 0 | 04-11-2013 02:30 PM |
So, what kind of power will a wraith axle handle? | Slowkrawl | Axial Wraith | 11 | 10-08-2012 11:27 PM |
How Much Power Can TLT's Handle? | crazyorigin | General Crawlers | 0 | 12-04-2009 07:08 PM |
how much power can a pede really handle?? | slobin3d | Non Crawler RC's | 9 | 02-19-2007 10:26 AM |
Loss of power in rear axle | zach3713 | General Crawlers | 5 | 10-03-2005 09:25 AM |
