02-11-2015, 03:02 PM | #1 |
Pebble Pounder Join Date: Jul 2012 Location: SJ
| Gearing vs motor
I have an axial wraith with weighted front wheels. All stocked electronics. I want more torque and want the motor to last. Should I regear or change motor? If regear, what gearing would work great with the stock motor and provide great torque and make the motor last? If I leave gearing the same, what motor should I get for more torque? |
02-11-2015, 03:40 PM | #2 |
Newbie Join Date: Jan 2015 Location: South of STL
| Re: Gearing vs motor
stock motor wont last all that long if youre crawling with it. you can regear to make it last longer with a bigger spur and smaller pinion if youre crawling but dont expect a 20t to last forever. if i were you start searching for motors and prepare for a brushless or brushed setup that fits how you drive.
02-11-2015, 04:03 PM | #3 |
Newbie Join Date: Apr 2010 Location: Apple Valley
I ran mine 14/87 on stock motor and electronics and it worked great for me. I am now brushless 9/56 on my Wraith 2s or 3s.
02-11-2015, 04:05 PM | #4 |
BTW, I'm now using a ROC412 3100kv. I also have an SCX10 on 10/56 with a TorqueMaster Pro 35t.
02-11-2015, 04:40 PM | #5 |
| Re: Gearing vs motor |
02-11-2015, 05:07 PM | #6 |
It does
02-11-2015, 05:51 PM | #7 |
Quarry Creeper Join Date: Jul 2014 Location: North Florida.
Not without elongation of the screw holes. I had to do that with a 16t..
02-11-2015, 05:54 PM | #8 |
02-11-2015, 05:59 PM | #9 |
The motor wont slide over far enough for the gears to mesh enough. . So you make the motor mount holes longer.. closer to the trans.. or use an 87t spur. ..
02-11-2015, 08:04 PM | #10 |
Quarry Creeper Join Date: Jan 2011 Location: 808 via Reno, Nv.
| Re: Gearing vs motor Yup that's the way to go, Im 88/15 here for a 5.8 ratio. Even if you elongate the holes which I have done, the issue you will have next is the motor will make contact with the transmission case which would still have too much play for proper gear mesh, and yes the factory spur gear cover does work with the 88t spur incase you were wondering.
02-12-2015, 05:24 AM | #11 |
RCC Addict Join Date: Feb 2012 Location: UK
Personally I have found 16/87 to be the sweet spot for both the Wraith and my SCX10. Running 27t or 35t motors. Primarily 2s but using 3s if a little more wheel speed is needed.
02-12-2015, 08:53 AM | #12 |
Does the factory spur cover work with an 87 spur?
02-12-2015, 12:01 PM | #13 |
Yes. :-)
Gearing vs motor - Similar Threads | ||||
Gearing or motor? | 6sharky9 | Newbie General | 9 | 08-11-2013 07:05 PM |
Motor and gearing... | silversweater | Electronics | 3 | 02-24-2013 09:47 PM |
20t motor and 45t motor gearing question? | rcstrike | Newbie General | 1 | 11-16-2011 03:40 PM |
motor gearing | grizz | Electronics | 2 | 02-26-2008 04:41 PM |
Motor Gearing | crawler nate 66 | Electronics | 0 | 01-28-2008 05:22 PM |
