06-26-2016, 02:18 PM | #1 |
Quarry Creeper Join Date: May 2016 Location: Nässjö
| Rims
I got my wraith kit all together. I now remember how much I hated to glue tires from when I drove rc 12 years ago. I also know that now I will have to rip it all apart again to get better foam and wheel weights. So I've bin looking on beedlock rims. It's a lot of info on some of the rims but everything is spread out. There is everything from cheap (eBay)to expensive rims but no info on the offset. I don't want my truck to get wider. I like the look of alu rims compared to the plastic axial beedlocks. So will I regret buying a set of https://www.ebay.com/itm/131414528438 Also when looking for rims I've seen some with air and not foam. Will air filled rims be a better choise? Cause new rims and foam even with the cheap rims will be just as much as a https://www.ebay.com/itm/301948340979 Skickat från min iPhone med Tapatalk |
06-26-2016, 04:12 PM | #2 |
Quarry Creeper Join Date: Dec 2013 Location: NoVa
| Re: Rims
Check out the Gearhead beadlocks. They can be flipped on the hub to be wide or narrow. I have 3 sets cause they're so nice. |
06-26-2016, 10:20 PM | #3 |
| Re: Rims |
06-27-2016, 07:47 AM | #4 |
Rock Stacker Join Date: Oct 2011 Location: milan
| Re: Rims
Hi look at ssd wheels from rpp I had a set and going to buy a set again for my wraith.And vanquish hubs fit right on. |
06-27-2016, 10:30 AM | #5 |
| Re: Rims
Gear Head wheels start at $139 and include the hubs. That's for 4 Delrin beadlocks with rings hardware & hubs. All Aluminum beadlocks start at $149 with hubs. Not sure where you looked. Try RPP Hobby. |
06-27-2016, 10:34 AM | #6 |
| Re: Rims
Thing is, I don't want to land much more then maby 120$ with foams. That's why I'm asking about these cheap eBay/Ali express rims. Skickat från min iPhone med Tapatalk |
06-27-2016, 10:42 AM | #7 |
Rock Crawler Join Date: May 2014 Location: Cluj-Napoca,Romania
| Re: Rims
SSD wheels have a look on amain.they around 40 for a pair and you can choose different hubs from VP if you are not happy with the stock ones Sent from my SM-N910F using Tapatalk |
06-27-2016, 10:46 AM | #8 |
RCC Addict Join Date: Jul 2009 Location: Ontherocks
| Re: Rims
Air filled tires are a fad. Good foams from Crawler Innovations are inexpensive and worth their weight in gold. Motoworx makes a high quality aluminum wheel that is is middle of the price rage (not more than 140 in most cases). DCW is a vendor on here who makes delrin wheels...I'm sure a basic delrin wheel can be had for a little under 100 CI foams are $20 to $25 Sure you can buy those cheap VP knockoffs, but there are better quality options out there |
06-27-2016, 11:43 AM | #9 | |
Quarry Creeper Join Date: Dec 2015 Location: United States
| Re: Rims Quote:
It may be a little difficult to get tires, wheels and foams for $120, but Duratrax has new crawler tires for $20 a pair with decent foams in them and Hot Racing has stamped steel wheels for $45-55 for a full set of 4. I've been happy with the 2-stage foams from Pro-Line (#6172-00), fit real well in 5.5-6.0" OD tires. They cost about $15-20 a pair depending on where you buy them. Duratrax 1.9/2.2 Scale Tires Hot Racing wheels, 12mm Hex white 4 BLW22H38 | eBay Last edited by Soldat Vaillant; 06-28-2016 at 02:02 PM. Reason: Typo | |
06-27-2016, 11:54 AM | #10 |
Quarry Creeper Join Date: Jan 2013 Location: Athens
| Re: Rims |
06-27-2016, 12:08 PM | #11 |
Newbie Join Date: Jun 2016 Location: Winchester
| Re: Rims
In this hobby you pretty much get what you pay for. I only like to spend my money once so do your research with that in mind. Basically bead locks are a worthwhile investment that you will enjoy long after you have forgotten what you paid for them.
06-27-2016, 12:09 PM | #12 | |
| Re: Rims Quote:
06-27-2016, 12:11 PM | #13 |
| Re: Rims Yes TSS as well. Never had a set myself but always heard good things.
06-28-2016, 12:16 PM | #14 |
Quarry Creeper Join Date: May 2007 Location: Montucky
| Re: Rims I have the second ones linked and am more than happy with them. They are skinny but my rbIIs mounted fine. Imo these wheels are really nice for the money.
06-28-2016, 01:48 PM | #15 |
| Re: Rims |
Rims - Similar Threads | ||||
rc4wd OEM rims on SCX10? Roxlox on proline rims? Plis help:) | msdelr | Axial SCX-10 | 27 | 05-21-2010 01:50 PM |
