Thread: Tummy Tuck
Old 02-04-2016, 06:53 AM   #81
Originally Posted by RockinTheSummit View Post
Cut bent and welded. I drilled out other side to save weight. Used some 3/4 in aluminum sleeves in between frame rails with long screws, makes everything sollid. I beat on 4s it makes sparks on rocks with sliders. Great mod very low cg side hills like no other
That's bad ass man! It's reassuring to hear that it has held up under 4s power. I'll be staying mine this weekend
mcnaney4x4 is offline   Reply With Quote
Old 02-04-2016, 11:22 AM   #82
Default Re: Tummy Tuck
Originally Posted by phillymade View Post
I'm torn on this mod. I would like to do it but am uncertain. It looks as though it changes the wheel base and possibly interferes with the links. is this fact or am I over thinking this?
No change of wheel base. Just do it. You'll love it.
Sent from my SCH-S968C using Tapatalk
panama is offline   Reply With Quote
Old 03-03-2016, 07:54 PM   #83
Welp I found a solution...throw money at it.
Had EmeryworX make some new lower rails for me. Was a bit of a fight to get them in since they have zero flex, but the result was worth it.
FaustKnight is offline   Reply With Quote
Old 03-03-2016, 08:27 PM   #84
http://www.rccrawler.com//www.pinter...ate/extension/
Those are nice! How much were they? And would they make more?
Old 03-03-2016, 08:30 PM   #85
I saw those rails. $75 is more then I wanted to spend. So I got a little creative tonight. I have no idea if it will work, but what the hell. Rails were already broken.
I shaved down the rails to fit inside some 1/4 brake line. Drilled some new holes and I'll shoegoo tomorrow(thanks for the tip Poprivet). Hopefully it'll hold for awhile.
raul shabinguez is offline   Reply With Quote
Old 03-03-2016, 09:07 PM   #86
$75, contact EmeryWorx via his thread in the chassis section.
Yeah they were a bit pricey, but pre-drilled and tapped and a really good fit made it worth it to me. Not to mention they're not aluminum (DOM). They fit in well with my plan to slowly build a full metal chassis.
Ran em a bit tonight for a test and I can climb much taller ledges than I could before. Also lowered my cg a bit and stiffened my chassis a LOT.
Old 03-03-2016, 09:11 PM   #87
Taking a new rail, cutting in the middle, then sleeving it with that same line would be a great idea too.
Old 03-03-2016, 11:24 PM   #88
What about a metal pipe shaved in half, or a plate for the screws to go through? All these are going with scx10 axles right, no ar60s?
phillyb is offline   Reply With Quote
Old 03-04-2016, 04:58 AM   #89
I've seen some ar60 axled tummy tucked wraiths, but yeah mainly scx10 1.9ers.
Old 05-08-2017, 09:10 PM   #90
I know this thread's a year old, but whatever. Been back and forth for a week or so on whether or not to do this to my 2.2 Wraith. Got a few in the tank tonight and went for it. I wish I knew how to post pics. Anyway, it was pretty easy. I had to ditch the spur gear cover and slide the skid/suspension/axles back about 1/2" to clear my front-mounted battery. I view this as a positive anyway to move the weight of the truck further forward. Also had to clearance the receiver box crossmember (factory spawn location) to clear the servo now that it sits a little further back and had to clearance the front of the skid to clear the driveshaft. Very small amount. Rear was fine. I am very happy with the results. Actually looks more scale. Only tested in the garage so far. Hopefully I get a chance to test tomorrow. The truck will now clear two 2x4s stacked with a 75% droop setup at ride height.
Myndefuk is offline   Reply With Quote
Old 05-17-2017, 03:34 PM   #91
Here was my solution for strengthening the chassis after doing a tummy tuck. I used some 1/4" plywood aluminum channel and drilled through it. Works great and almost acts as a rock slider too.
MaxxCrawl is offline   Reply With Quote
Old 05-17-2017, 04:54 PM   #92
When I did my tummy tuck I made sure that I made my screw holes for the plate large enough for the screws to slip through easily then I touched the top of where the screws would go in flatten the edge of the rail just enough so the screws set flat I've had no pinching of that and no breakage and I've had my tummy tuck for a year
Sent from my SCH-I545 using Tapatalk
Old 05-17-2017, 06:23 PM   #93
I'm fairly new to battery RC's in general let alone Wraiths, I'm a converted Nitro runner. I picked up the spawn kit a few weeks ago and I love it. I'm seriously considering doing this mod, but here's my question... is it an ok mod to do running a factory setup with the 2.2s? Second question... would i need any additional parts to make everything work after the mods. My spawn is pretty much a factory kit setup with the Axial 55T motor and a crappy servo that i am looking to upgrade soon. Thanks in advance for the help.
ACU18 is offline   Reply With Quote
Old 05-17-2017, 06:25 PM   #94
Fairly easy. Good with stock setup. No addition as l parts needed.
Old 05-17-2017, 06:34 PM   #95
Awesome, thanks for the fast reply. I might copy MaxxCrawl's idea and use some 1/4 inch C channel to give a bit more strength.
Old 05-17-2017, 06:36 PM   #96
That was a nice idea. Dual purpose strength and rock sliders
Old 05-23-2017, 06:22 PM   #97
I really thought long and hard, I want my clearance and sliders too.
Wertymade WM03 stinger and sliders together. I can always use nose weight, this will add a bit, but more stiffness from the front to the rails
Hang up and Drive
mikemcE is offline   Reply With Quote
Old 06-06-2017, 03:56 PM   #98
I finally got around to doing mine. I posted the pics on my rigs thread.
"Blue" another new guy with a spawn
Old 03-23-2021, 08:21 AM   #99
Recently purchased a Wraith Spawn, and consequently have been drawn to this forum as I have researched tons of tips/tricks and hacks for this platform.
I am interested in doing this mod for clearance but it is not clear to me from just pictures what it is that I need to do.
Can someone please explain to me where to start?
Den72 is offline   Reply With Quote
Old 03-29-2021, 01:36 AM   #100
Tummy tuck requires you take your 2 lower frame rails, cut off the bottom hoop & re-drill at least 2 holes back into the rail above it (doesn't need all 4 on each side)
Whilst it will increase clearance, if you don't make some other changes as well it will effect your link geometry, not necessarily for the better.
The tummy tuck also raises the the trans & motor in the chassis, raising the overall Center of Gravity (CoG) making it more inclined to roll over.
The counter to this is softer springs & lower ride height, somewhat negating the clearance gain under the skid in the first place.
altd896 is offline   Reply With Quote
Tummy Tuck - Similar Threads
Tummy Tuck HELP! Deezul General Crawlers 4 05-14-2006 09:44 PM
tummy tuck jeep511 General Crawlers 2 04-14-2006 08:10 AM
my tummy tuck Derek General Crawlers 8 02-22-2006 06:47 PM
Another tummy tuck scout21972 General Crawlers 16 02-02-2006 01:36 PM
