06-01-2015, 08:11 AM | #1 |
Quarry Creeper Join Date: Aug 2014 Location: holland
| Serious steering binding
Anyone ran into this problem before? Recently I lowered my Wraith by flipping the link/shock brackets on the axles and moving the front shocks to the most aft position (and rear shock to the foremost position, but that is not relevant). The upward travel of the front axle is high enough to make the top steering link sink between the sway bar mounting points. This causes severe binding when turning (Left in this case). Combined with 25kg/cm (345 oz/i), in my case this led to the distruction of one of the gears in the servo. Luckily I could rebuild it and by mounting this gear 180degr. rotated. It's running fine again. In order to prevent this from happening again I moved the front shocks to the foremost position which in turn limits the uptravel of the axle. Now it stays clear of the mounts. All in all: solved for now! Every ‘problem’ I ran into thus far was more or less expected because it was mentioned somewhere on this forum. This one I didn’t come across my reading. I wonder has anyone else encountered this problem and are there other solutions I haven’t thought about? |
06-01-2015, 08:31 AM | #2 |
Rock Stacker Join Date: Mar 2015 Location: Mahopac
| Re: Serious steering binding
My spectrum servo fit in there nicely. But my savox hit. I cut down the mounts as to recess the servo a bit. Then it fit up in the frame perfect. You don't want to limit travel if you don't have to.
06-01-2015, 10:03 AM | #3 |
I make a servo mount that moves it back far enough to clear the cage. Not in stock at the moment, but I hope to have some soon... If you've got the tools, you can drill new holes in your existing mount to get it moved back. Just be careful that you don't go too far and have the back end hit. |
06-01-2015, 11:57 AM | #4 |
I wanna be Dave Join Date: Nov 2014 Location: West Texas
Dude How much do you charge for the servo plate I saw it on super shafty? |
06-01-2015, 12:01 PM | #5 |
The same.
06-01-2015, 12:17 PM | #6 |
I did move the servo back. Pics are in post 5 of my 'uprising' topic. Can't go any further because the bolt though the link and horn will touch the diff house. Might grind it down a bit but it won't give me that much space.
06-01-2015, 06:57 PM | #7 |
RCC Addict Join Date: May 2013 Location: Forrestfield, Western Australia
I had a fix for your screw hitting the diff cover but just realised you can't do it using the stock linkages. If/when you change out the plastic stock tie rod & drag link you can roll the servo over & run the drag link to the left knuckle instead of the right. This will get that screw away from the diff cover. I also changed to the RCBros servo posts, they're a bit thinner than the stock plastic & pull the servo back a bit. |
06-02-2015, 12:10 PM | #8 |
Rock Stacker Join Date: Mar 2012 Location: SoCal
Another option is to use four small spacers to bring the front bumper forward to clear the servo arm.
06-03-2015, 01:55 AM | #9 |
Newbie Join Date: Dec 2014 Location: Sydney
I just trimmed the sway bar lug off
06-03-2015, 02:19 AM | #10 |
| Re: Serious steering binding |
06-03-2015, 03:59 AM | #11 |
I joined the Band! Join Date: Dec 2014 Location: Earth
| Re: Serious steering binding I extended mine with a couple of 1mm thick x 5mm ID O-rings. You may need a little more space than that, but two O-rings each on the bottom screws and one each on the top screw worked for mine.
Serious steering binding - Similar Threads | ||||
BTA Steering Binding Question | wickedwenzel | Axial AX-10 Scorpion | 2 | 02-29-2012 05:21 PM |
Steering Binding | Mac28 | G-Made Crawlers | 2 | 06-21-2011 10:01 PM |
steering binding issue | JaredVW | Axial AX-10 Scorpion | 22 | 07-16-2010 12:10 AM |
Steering link Binding on NN chassis | koyote | Tamiya Clod Buster | 5 | 02-16-2007 06:36 PM |
Steering links binding on a NN chassis | koyote | Newbie General | 1 | 02-11-2007 03:36 PM |
