04-20-2016, 02:21 AM | #1 |
RCC Addict Join Date: Oct 2014 Location: UK
| New SSD 2 Speed Transmission kit for Wraith 2 Speed Transmission Kit for Wraith CNC machined aluminum transmission case CNC machined aluminum 3mm thick motor mount Wide hardened steel 48 pitch gears Hardened steel output shaft Shift servo mount fits standard and mini servos Same mounting as stock Axial Wraith & SCX10 transmission Fits stock Axial transmission input shaft Fits stock Axial transmission gear cover Direct fit into Axial Wraith This is a conversion kit, not a complete transmission. Internal 1st gear ratio: 4.91:1 (stock Axial is 2.6:1) Internal 2nd gear ratio: 1.8:1 |
04-20-2016, 02:34 AM | #2 |
| Re: New SSD 2 Speed Transmission kit for Wraith
No other 2 speed can do this: Last edited by SSD; 04-20-2016 at 02:41 AM. |
04-20-2016, 06:51 AM | #3 |
Is it just the top shaft, top gear, spur, and slipper assembly that is required for completion the conversion? Obviously, a shifting servo is also required as well.
04-20-2016, 09:57 AM | #4 |
| Re: New SSD 2 Speed Transmission kit for Wraith |
04-20-2016, 05:19 PM | #5 |
Quarry Creeper Join Date: Apr 2014 Location: a land bereft of rocks
Dannngggg first gear is gonna crawl!!!!!!!!! I think I need this
04-21-2016, 10:46 AM | #6 |
Quarry Creeper Join Date: Dec 2013 Location: NoVa
The big Question is WHEN?
04-21-2016, 10:59 AM | #7 |
RPP will have them next week. Other dealers should follow as soon as they order...
04-21-2016, 12:19 PM | #8 |
Ive got the SSD Yeti 2 speed. was a nice kit. this one looks even better!
04-26-2016, 07:05 PM | #9 |
I might need one of these for the Hack! Oh and those nifty diamond axles!
04-26-2016, 08:43 PM | #10 |
Pebble Pounder Join Date: Jul 2012 Location: Overton
Any idea on how it holds up to Brushless?
04-27-2016, 02:13 AM | #11 |
All steel internals. It is a proven design, will be fine.
04-27-2016, 01:48 PM | #12 |
I just got the "in stock" email from RPP. I ordered one...
04-27-2016, 02:27 PM | #13 |
04-27-2016, 02:45 PM | #14 |
04-30-2016, 12:42 PM | #15 |
Got it today. I must say, the fit & finish is awesome. I won't get to install for a couple days. I'll let you know how that goes. |
05-02-2016, 03:30 PM | #16 |
Runs Like a champ. Very smooth & quiet. Not sure yet if it will hold up to the Pro4 HD but, around the yard, it's great. The gear ratios are very low crawl & almost too fast which is just how I like it. You have to pay attention or damage is certain. I'm using the Spawn "semi scale" interior on this wraith and the servo does touch the bottom of the trans tunnel. A smaller servo would do the job and might help the spacing. |
05-02-2016, 03:59 PM | #17 | |
Quarry Creeper Join Date: Mar 2015 Location: Woodland
| Re: New SSD 2 Speed Transmission kit for Wraith Quote:
Oh, and keep up the awesome work SSD, I bet this trans is just as beautiful as the diamonds i got from ya. | |
05-05-2016, 11:12 PM | #18 |
Newbie Join Date: Feb 2016 Location: In Merica
I need to get one of these ASAP. Does RPP still carry them? And will it hold up to a Puller Pro 3500kv xl?
05-06-2016, 03:51 PM | #19 |
Anyone have the measurements for height?
05-07-2016, 03:21 AM | #20 |
It is the same height as a stock trans as the gear cover fits.
New SSD 2 Speed Transmission kit for Wraith - Similar Threads | ||||
The New SSD-RC High Ratio Wraith Transmission Kit | KRAWLR4life | Axial Wraith | 18 | 08-22-2016 05:14 AM |
RTR Yeti: Servo and radio options for SSD 2 speed kit? | KellyC | Axial Yeti | 10 | 06-22-2015 07:14 PM |
