11-13-2018, 05:19 PM | #21 |
RCC Addict Join Date: Sep 2017 Location: The OC
| Re: Decided to build a fancyish wraith...
Don't thank me yet...I haven't actually tried it. Just read you can fairly easily de-anodize aluminum with 'Greased-Lightning' cleaner and degreaser. Polishing is fairly straightforward if you have a bench grinder with a polishing wheel. I've been dying to try it though... Here's a threadpost about the process: https://www.rcgroups.com/forums/show...easy-Very-fast |
11-13-2018, 05:26 PM | #22 |
Quarry Creeper Join Date: Feb 2018 Location: Melbourne Australia
Honestly, For 9bucks delivered to Aus, I'll just buy new ones on ebay.... Sent from my LG-H870DS using Tapatalk |
11-14-2018, 02:34 PM | #23 |
| Re: My late 2018 Wraith Build... Trying to be Fancy, but cool too.....
Latest update, fixed the transmission mounts Sent from my LG-H870DS using Tapatalk |
11-14-2018, 02:42 PM | #24 | |
| Re: Decided to build a fancyish wraith... Quote:
Agreed. They just don't sell raw alloy rings - they're all a 'color' - even the brite ones are anodized silver, not bare aluminum. I don't know why. [shrug] And if you buy their 'beef-patties' the hub screws are too short then. I've messaged them but no reply, I suspect a language barrier. But their finished hubs package has the perfect screws with them. Everything at the local industrial supply had too large of a head to fit into the socket in the wheel. Ah well.... | |
11-14-2018, 02:58 PM | #25 |
True, Might be worth trying it on a spare set of rings id spend 9 bucks for the experiment... They do also have Matt Silver which should take paint well.... |
11-14-2018, 05:05 PM | #26 |
Some more parts came in... The GRC shock mounts look awesome, looking forward to giving them a crack. Also new truss mounts and titanium coated axle gears Sent from my LG-H870DS using Tapatalk |
11-14-2018, 05:40 PM | #27 |
RCC Addict Join Date: Sep 2010 Location: Apollo Pa
Parts deliveries always make for a good day! |
11-18-2018, 09:07 PM | #28 |
I can not recommend the extra speed titanium coated diff gears. However the GRC damper mounts are super rad. they are designed to have longer rear shocks, so bare this in mind if you are going to order some. I have ordered some gmade XD shocks, 103mm for the rear and 93mm for the front. hope they go ok! I also swapped in a Tekin Element Proof 2300kv 4pole sensored motor with a mamba max pro 1 cell esc, and a CC10amp BEC. I installed the standard axial HD gears. will upload pics soon... |
11-19-2018, 06:15 AM | #29 |
Pics Sent from my LG-H870DS using Tapatalk |
11-24-2018, 06:49 AM | #30 |
RCC Addict Join Date: Sep 2014 Location: Ft. Lauderdale, Florida
That's a slick looking rig! Sent from my LM-G710VM using Tapatalk |
11-24-2018, 10:35 AM | #31 |
Looking great! Which body is that? I probably missed it somewhere |
11-24-2018, 03:23 PM | #32 |
It's the poison spider body painted Tamiya bright silver... Sent from my LG-H870DS using Tapatalk |
Decided to build a fancyish wraith... - Similar Threads | ||||
So I decided to build a crawler... | wbw2 | Axial AX10 2nd-gen | 6 | 03-17-2015 08:21 PM |
Decided to build a Sportsman Crawler but.... | redsawacs | Axial AX-10 Scorpion | 27 | 01-09-2014 09:53 PM |
Decided to build my 1st crawler | Maverick52 | General Crawlers | 27 | 03-08-2013 10:58 PM |
Decided to not build a wheely king | drftfan | Axial AX-10 Scorpion | 6 | 03-23-2008 11:51 AM |
