01-25-2020, 07:51 AM | #1 |
Newbie Join Date: Jan 2020 Location: West TN
| Noobie here
Thanks for the ad. Pretty new to the hobby world but what I have experienced so far has been awesome. Decided I wanted a decent crawler so I have done alot of research and finally found the crawler for me. Pulled the trigger on a Spawn. Should be here in a couple of days. Any tips or tricks I should be aware of ?
01-25-2020, 10:59 AM | #2 |
RCC Addict Join Date: Mar 2019 Location: Hemet
| Re: Noobie here
Hey welcome! The spawn was my first crawler back in May, since then I added an scx10 ii to the mix. As far as mods, there’s a bunch floating around here. Harley’s got a pretty good thread going. I did mine on somewhat of a budget, first thing was moving the battery tray forward. I went over it a little in my wraith thread. I then set up the suspension for droop which helped but ultimately ended up with some 110mm king shocks. If you’re just crawling the rc4wd 35t motor was a great upgrade and while you’re there add steel gears to the transmission. Eventually you’ll want to upgrade to a high torque steering servo and castle BEC but I waited until I wore out the stock one. *Vanquish incision steering links are a great upgrade too and an aluminum servo Horn Otherwise just enjoy the thing! They’re a blast Last edited by Fricker08; 01-25-2020 at 11:02 AM. |
01-25-2020, 12:33 PM | #3 |
Rock Stacker Join Date: Nov 2009 Location: Santa Rosa, CA
| Re: Noobie here
x2 on moving the battery up front right away, getting a powerful steering servo & BEC installed, and the Incision steering links Wraiths are awesome, congrats on your new acquisition! Sent from my iPhone using Tapatalk |
Noobie here - Similar Threads | ||||
noobie ? | freewheelinbronco | Newbie General | 2 | 03-14-2010 06:21 PM |
noobie ?'s | cavie98 | Newbie General | 2 | 12-12-2008 09:00 PM |
noobie ?'s | cavie98 | Newbie General | 0 | 12-12-2008 12:35 PM |
Noobie needs some help | 3speed | Newbie General | 2 | 11-11-2008 08:34 AM |
Noobie :D | AFJ | Tamiya Txt-1 and Juggernaut | 5 | 04-28-2004 04:30 AM |
