05-23-2012, 04:29 AM | #521 |
Quarry Creeper Join Date: Sep 2008 Location: Isle of Man
| Re: a tuber
Wouldn't it have been easier to turn the cans down to 0.5mm all round and add the weight out wide on the end of the axles?
05-23-2012, 06:06 AM | #522 |
RCC Addict Join Date: Jan 2005 Location: Germany north
| Re: a tuber |
05-23-2012, 07:15 AM | #523 |
RCC Addict Join Date: Oct 2008 Location: Finland
| Re: a tuber |
05-23-2012, 08:44 AM | #524 |
| Re: a tuber
Amazing video Christan, the rig is amazing your breaking trial on many things, outstanding work.
05-23-2012, 09:23 AM | #525 | |
I wanna be Dave Join Date: Apr 2007 Location: Arlington, Washington
| Re: a tuber
Off center lathing eh? I never thought of that! Sounds interesting! Where are the pics though? Pics or it didn't happen. Later EddieO Quote:
05-23-2012, 10:22 AM | #526 |
Christian, where you turned it off centre, where is the 1mm section in relation to the magnets, maybe the weak point is between the magnets, maybe you could fill the gap between the magnets with 1mm shim to keep the magnetic field strength high Sent via Smartassphone & Tapatalk 2 |
05-23-2012, 11:07 AM | #527 | |
| Re: a tuber Quote:
Your continued desire to push the envelope with creative thinking just astounds me. I don't think my imagination was nearly as big, even as a child. Phenomenal work! | |
05-23-2012, 01:43 PM | #528 |
| Re: a tuber |
05-23-2012, 03:56 PM | #529 |
| Re: a tuber
Wait, so one side has more steel behind the magnet than the other? Or am I seeing things? I thought u were saying that the can was thicker on the pinion side than it was on the end bell side or vice versa Later EddieO |
05-23-2012, 04:45 PM | #530 |
Rock Crawler Join Date: Jun 2011 Location: San Diego
| Re: a tuber It's like he messed up and the can was not centered in the chuck. |
05-23-2012, 06:24 PM | #531 |
No, he's turned the whole can off centre so the thicker/heavier side is at the bottom thereby lowering the CoG Sent via Smartassphone & Tapatalk 2 |
05-24-2012, 01:22 AM | #532 |
| Re: a tuber
Did you weld brackets onto your front lower links to mount the front shocks? Brilliant and noted!
05-24-2012, 01:31 AM | #533 |
| Re: a tuber |
05-24-2012, 01:18 PM | #534 |
I wanna be Dave Join Date: Oct 2006 Location: Milwaukie OR
| Re: a tuber
I read, and couldnt find it, but how much weight did you save by lathing your cans, and what is the diameter you turned it to? You mention the drag brake was weaker. Does the off set lathing help that any?
05-24-2012, 02:07 PM | #535 |
| Re: a tuber
I think this is the first mod we've seen from Christian that is dubious at best
05-24-2012, 02:14 PM | #536 |
| Re: a tuber |
05-24-2012, 02:39 PM | #537 |
I wanna be Dave Join Date: Dec 2008 Location: ?
| Re: a tuber |
05-24-2012, 03:08 PM | #539 |
| Re: a tuber
Servo mod was a great way to gain clearance to push the servo back thereby moving the servo arm back and out of snagging distance of rocks
05-24-2012, 03:48 PM | #540 | |
| Re: a tuber Quote:
a tuber Last edited by TSK; 05-24-2012 at 03:52 PM. | |
