12-17-2012, 03:38 AM | #621 |
Quarry Creeper Join Date: Sep 2008 Location: Isle of Man
| Re: a tuber
I think he already has 130°
12-17-2012, 01:57 PM | #622 |
RCC Addict Join Date: Jan 2005 Location: Germany north
| Re: a tuber
bla bla ... the rear spool |
12-17-2012, 02:17 PM | #623 |
| Re: a tuber
looks like i forgot the front one |
12-17-2012, 03:13 PM | #624 |
| Re: a tuber
What materialize you use for the spools? Quite a dramatic difference in weight
12-17-2012, 05:16 PM | #625 |
Do I sense a chassis upgrade in the pipeline too?
12-17-2012, 05:33 PM | #626 |
I wanna be Dave Join Date: Oct 2004 Location: QC-AZ
Just looking on my phone but it looks like you removed the steel bearing races? Either way it's looking sick as hell and I love when so much effort goes into a part you will never see.
12-17-2012, 07:18 PM | #627 |
Rock Crawler Join Date: Sep 2009 Location: Orangevale
| Re: a tuber
I am sure when it is his turn to be awake he will fill us in. But to me it looks like the rear spool is drilled out and he will press fit a rear shaft. And the front is not drilled out and has a brass splined insert for the new front axles. Looks great and I could be way off but great work Christian as all ways I love watching your builds. |
12-18-2012, 12:09 AM | #628 |
| Re: a tuber
the rear steel spool is drilled out to 16mm ID , so the steel part of the spool is ~4.5g only the center is made of 7075 aluminium , itīs drilled out to 6mm for glueing in a 6mm hollow Ti shaft steering will be ~80° , for the most constant velocity i need an 1.3mm offset from the kingpin to the double joint center , thats the max i can get out of the VP knuckles and Chubs + ~2mm axial movement , thats why the splined front shafts and spool another xr10 for a buddy thats the chassis i will use |
12-18-2012, 01:29 AM | #629 |
| Re: a tuber
So the axle & spools are splined because they will have to telescope slightly in the housing to achieve your full steering angle? And since you are gonna switch to the new chassis, does that mean the Ti tuner gets to retire in hawaii? |
12-18-2012, 01:56 AM | #630 | ||
| Re: a tuber Quote:
The rear could have been splined too as it has to be better than two flats on the shaft, but there's obviously a weight penalty | ||
12-18-2012, 08:39 AM | #631 |
| Re: a tuber But I think Christian has ran a solid one piece rear shaft for a long time so why change it no slop and strong.
12-18-2012, 09:06 AM | #632 |
| Re: a tuber |
12-18-2012, 09:20 AM | #633 |
Rock Crawler Join Date: Mar 2008 Location: amherst, ny
| Re: a tuber
Quality work! Great engineering
12-18-2012, 01:42 PM | #634 |
2013 2.2P Nat. Champion Join Date: Sep 2009 Location: BorderLine Crawlers Season 3 is on!
| A Christmas Story
Ah it's so much fun to watch a bitchin' Christmas time build thread with visions of one-offs dancing in Christian's head. This is crawling. Hope she's ready for May. J |
12-18-2012, 01:44 PM | #635 |
Newbie Join Date: Mar 2010 Location: europe:P
| Re: a tuber
Keep going Chris (i think right?) keep up the good work and keep on showin' off';)
12-18-2012, 02:52 PM | #636 |
| Re: a tuber |
12-18-2012, 03:00 PM | #637 |
E.Y. Designs Join Date: Sep 2011 Location: Springfield, OR
| Re: a tuber
Hurry up and get that all put together... Can't wait to see it! So does this increase the front end width?
12-18-2012, 03:31 PM | #638 |
| Re: a tuber |
12-19-2012, 01:49 AM | #639 |
| Re: a tuber
some weight saving |
12-19-2012, 01:12 PM | #640 |
| Re: a tuber
some progress |
