09-18-2010, 02:20 PM | #41 |
RCC Addict Join Date: Jan 2005 Location: Germany north
my rear axle gears after 10 packs all bearings are ok too |
09-18-2010, 02:25 PM | #42 |
Rock Crawler Join Date: Feb 2008 Location: Dortmund, Germany
09-18-2010, 02:36 PM | #43 |
all stock but i will switch to ceramics and 5x10 for the final driveshaft now |
09-18-2010, 04:29 PM | #44 |
some pics of the 5x10 flanged bearing mod drilled out to 10mm .2mm grinded off the 36t and .3mm of the top housing stock after grinding fits nice added a .2mm shim between the bearing and the 12t gear and a .2mm shim to the stepped gear all bearings are ceramic abec5 the flanged ones are glued in w. Loctite 638 |
09-18-2010, 05:21 PM | #45 |
I wanna be Dave Join Date: Sep 2009 Location: Nor Cal
Thats gonna be a tough gearbox! I too have about 10 packs of hard runnin' through my XR and the gears look perfect in mine as well. Front and rear |
09-20-2010, 12:21 AM | #46 |
got some titanium lowers and some steering upgrade switched to the 14mm rotors and 17t pinion in front and 16t for the rear |
09-21-2010, 05:28 PM | #47 |
RCC Addict Join Date: Jun 2009 Location: California
Nice....looks good, USA always gives EGRESSor the 3m with the stock rod ends?? no breakage there yet?? 2345g = around 5.1lbs? You have your hands on a bunch of Ti links?? Could be something good to sell. Everyone loves a Ti link... Any new updates? You must be doing something new. |
09-21-2010, 11:27 PM | #48 | |
i´ve got the Ti links from mattin , the are 6mm in diameter w. 4mm ends the xr10 rodends are drilled out to fit the M4 i will use trx Revo or Jato rodends after the xr10 ones wear out only update for now some bigger rings for the front rims Last edited by EGRESSor; 09-22-2010 at 01:23 AM. | |
09-24-2010, 12:42 AM | #49 |
just made a set of wheel weights 120 gramm ea. this adds 2 degrees when i climb a board but i think it runs better without the weights |
09-24-2010, 01:04 AM | #50 |
Quarry Creeper Join Date: Dec 2009 Location: San Jose
Video please!!!!! I want to run this motor setup, with m2 or whatever i can for dig. Do you like the brushless on it? Also- I didn't realize it 4 days ago but i askeD about the 7980 as well! Good show man! This oooooooozes sex appeal |
09-24-2010, 01:28 AM | #51 |
Quarry Creeper Join Date: May 2008 Location: Clarkston
09-24-2010, 01:52 AM | #52 | |
but works well i run 2s lipo in that rig and power the servo directly >> endless torque and its damn fast too that will be funny | |
10-07-2010, 09:46 AM | #53 |
some work on the servo mount |
10-07-2010, 10:01 AM | #54 |
Rock Crawler Join Date: Jun 2006 Location: Wisconsin
Wow, this is a clean, nicely modified XR10. The tube chassis is so simple, yet pleasing to the eye, and functional. I like it. Everything looks so clean and well built.
10-07-2010, 10:36 AM | #55 |
RCC Addict Join Date: Jul 2009 Location: Farmington, NM
Damn I forgot all about this build. Looking sweet. Got any video's yet?
10-07-2010, 11:02 AM | #56 |
Rock Crawler Join Date: Dec 2008 Location: With the ATL Crawlers
18.5t or 21.5t? Also, plenty of power and torque w/ running 2s?
10-07-2010, 01:08 PM | #57 |
10-07-2010, 02:51 PM | #58 |
Rock Stacker Join Date: Oct 2009 Location: Boston
That tuber looks sick....good job there....what are those wheels you are using? are they available for sale?
10-08-2010, 09:39 PM | #59 |
Notice any excessive hang-up's from the new steering Tie-rod? Whats the ground clearence on these axles?
10-15-2010, 02:54 PM | #60 |
