Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Axial XR10
Thread: a tuber
Old 09-09-2010, 02:35 PM   #21
I'm curious how the axles will hold up with a brushless system...Be cool to see it
running.
fa1rch1ld is offline   Reply With Quote
Old 09-09-2010, 02:41 PM   #22
Originally Posted by EGRESSor View Post
the wheels for it
plates are stainless steel ,3mm
hubs made of 7075 alu
inner ring 6061
outer ring is delrin
not really lightweight but it should work
NIce wheels who make those?
sally1800 is offline   Reply With Quote
Old 09-09-2010, 02:52 PM   #23
Originally Posted by TheSCorpionKing View Post
So what you gonna do with the ax????
i will drive it for fun
running.
me too
but Uli still runs his xr10 with 17.5´s I´m having serious GAS
and it works great
EGRESSor is offline   Reply With Quote
Old 09-09-2010, 03:04 PM   #24
Uli
Pretty truck. Me like.
Uli is offline   Reply With Quote
Old 09-09-2010, 04:40 PM   #25
TSK
Shelf queen
TSK's Avatar
Those are Felsenfest Special Editions
TSK is offline   Reply With Quote
Old 09-10-2010, 11:20 AM   #26
just need to prog the esc´s and the react
and it needs some panels
Old 09-10-2010, 11:32 AM   #27
And add your Prototyp knuckels and steering kit on it ... and you need some Ti links
It is the cleanest tuber i ever seen
Awesome
stediju is offline   Reply With Quote
Old 09-10-2010, 03:54 PM   #28
TSK
Shelf queen
TSK's Avatar
Are the front shocks laid back likethat for BTA linkage clearance?
Old 09-10-2010, 05:25 PM   #29
avoidsthelight's Avatar
Default rats
damnit...i just put clean underwear on and then i see this... thanks alot man.
sick, cant wait to see this running. i want to know how your brushless does. i am planning on doing something close to but not the same.
avoidsthelight is offline   Reply With Quote
Old 09-10-2010, 06:47 PM   #30
progress
hope to get the electronic done within the next 2 hours
Yes please, where do I send my money?
CreepyCrawl is offline   Reply With Quote
Old 09-11-2010, 05:33 PM   #31
ready to rock
Old 09-11-2010, 08:50 PM   #32
ready to rock
"to rock" and outright rocks!
The work is most impressive!
ARC MotorSports is offline   Reply With Quote
Old 09-13-2010, 02:27 PM   #33
it drives nice
just wanted to post some beauty shoots before i start to scratch it
Old 09-13-2010, 02:29 PM   #34
I LIKE IT!!! good job
aaugman is offline   Reply With Quote
Old 09-16-2010, 01:51 AM   #35
i´m very impressed after 3 hours of runtime
this rig performs damn cool
i run it without any additional weights
it easy climbs steep walls and flies from rock to rock
and nothing is broken after alotof hard binds
i totally forgot to take some action pics
but that was the area
Old 09-16-2010, 02:45 AM   #36
compliments from Italy!!!
The rig is light!..which foams do you use for Boss ?
record some videos ;)
guidetti_angelo is offline   Reply With Quote
Old 09-16-2010, 03:37 AM   #37
thank you
Jake sent me some Losi oversize memorys for the front tires and some non memory foams for the rear
they work perfect
Old 09-16-2010, 03:58 AM   #38
i also bought a set of oversized losi memory but with berg axles and weight addes to wheels they droop too much, now i have on the way a new set of nova foams with memory outer and i plan to reduce weight of my berg axles by lathe..
Old 09-16-2010, 05:41 AM   #39
the Losi foams are perfect for my narrow rims , they are 15mm ~.6" between the rings
Old 09-16-2010, 06:32 AM   #40
i'm curious to see it on the rocks, post one video
