10-02-2010, 03:28 PM | #1 |
| DT's UGC Viper
Specs are: Underground Crawlers Viper Chassis VP DH's with rover sedona, or claw up front SLW V3's and v4's with rover, sedona, or claw on the rear All tires stuffed with some combination of Nova foams 35t Brood Limited Edition motors with 35t HH matched motors as spares FXR x2 Hitec 7950th CC BEC Traxxas big bores Losi gold springs Jeepin' Dougs C Cups drilled to fit axial shocks Crawler Innovations servo guard BWD servo mount Axial 101mm bent links for upper links Crawler Innovations low clearance links - front t1e high clearance lower links - rear HR steel gears VP knuckles VP Chubs VP tranny cases 9mm bearing mod crazyorigin big bore v2 shock caps with revo ends crazyorigin battery mount\motor guard Not much "XR" left Here is the rig currently: and where it began: I chewed up the spool on a high throttle rear burn that found high traction, wadded the rig up bad and Whirrrrrrr, click, click, click.... Last edited by DickyT; 01-17-2011 at 11:24 AM. |
10-02-2010, 04:09 PM | #2 |
Rock Crawler Join Date: Nov 2009 Location: Wildwood
I was going to say it was the best looking one I had seen, until I got to the last 2 pics. Ouch.
10-02-2010, 04:14 PM | #3 |
Rock Crawler Join Date: Mar 2008 Location: ...in your meter box...
Subscribed!
10-02-2010, 04:17 PM | #4 |
RCC Addict Join Date: Nov 2008 Location: I don't think theres rocks in Florida
I'm really sorry to see that happen to you. Atleast it wasn't on the maiden voyage..... Oh, wait it was... Hopefully axial will take care of you quick. Are all the bearings still intact? |
10-02-2010, 04:21 PM | #5 | |
My motors are out of spec per recommendations. It was only a matter of time before I destroyed cast gears. | |
10-02-2010, 04:22 PM | #6 |
Quarry Creeper Join Date: Jan 2009 Location: Rocklin
Looks good(minus the gears lol) when will you install the bodiless chassis ?
10-02-2010, 04:24 PM | #7 |
10-02-2010, 04:35 PM | #8 |
I wanna be Dave Join Date: Dec 2009 Location: Lady Lake, Fl
10-02-2010, 07:35 PM | #9 |
Rock Crawler Join Date: Jun 2009 Location: Minnesota
subscribed |
10-02-2010, 08:20 PM | #10 |
Rock Crawler Join Date: Jul 2009 Location: boise
ive got to see the chassis! juan makes amazing stuff!!! subcribed
10-02-2010, 08:23 PM | #11 |
Quarry Creeper Join Date: Jan 2009 Location: Elko Co.
PURDY!! |
10-02-2010, 11:11 PM | #12 |
I got some rear links done tonight. |
10-03-2010, 12:05 AM | #13 | |
RCC Addict Join Date: Mar 2010 Location: Auburn, MI
Looks good. That rear spool looks farmilliar. I did the same thing last night with 45t motors. Got a little happy with the throttle, car took a BIG bounce and boom, click, click, click. Took teeth off the spool and the final drive gear. Let me know what you do to get the shocks to stop leaking. I have two now that are leaking, both at the caps. I am thinking I will need to get some aluminum caps or different shocks. | |
10-03-2010, 12:55 AM | #14 |
Nice job on the bends...looks like they hit the uppers pretty quick though. Are you getting enough articulation out of that set up. - |
10-03-2010, 01:42 AM | #15 |
| Only when on the lowest hole as pictured. After todays driving I think I like the next one up, which gives plenty of room. I have a bit too much rear bite on the lowest hole. Regardless there is plenty of articulation. The drill bit box is 6 inches.
10-03-2010, 12:49 PM | #16 |
Did some work on the electronics\battery tray and finished up the links. |
10-03-2010, 03:04 PM | #17 |
RCC Addict Join Date: Feb 2008 Location: Winnipeg
Bling bling subscribed!
10-03-2010, 06:19 PM | #18 |
10-03-2010, 06:58 PM | #19 |
Those rear links are WILD!! I like um |
10-04-2010, 10:31 AM | #20 |
Tiny goodness showed up today, buh bye Mamba Max |
