01-09-2011, 11:37 PM | #101 |
01-10-2011, 10:46 AM | #102 |
01-12-2011, 04:19 PM | #103 | |
I wanna be Dave Join Date: Feb 2005 Location: Burnsville
You're both right. On one side I will wrap the RX antenna and on the other side I will wrap the ESC wires. I have read that this RX does not perform well with the antenna stuffed into the case. I will try it just to be sure though. | |
01-12-2011, 04:27 PM | #104 |
One side mounted up.... There will be a small part to act as a clamp for the wires. I usually cut the on/off switch off of ESC's, but being a new dual setup I want to keep them on until I am confident in their programming. I drilled and tapped the switches to 3mm and mounted them to the chassis plate. They cannot 'accidentally' be turned OFF, because the switch is locked in the hole in the chassis. I always unplug the battery to turn off the rig. But if I need to reprogram an ESC, I can remove the switch to do so. And they are out of harms way. |
01-12-2011, 08:44 PM | #105 |
Rock Crawler Join Date: Jun 2010 Location: Yelm,WA
Clever idea on the mounting of the on/off switch for the ESC's, I would have never even thought about doing something like that |
01-13-2011, 12:14 AM | #106 |
Quarry Creeper Join Date: Nov 2010 Location: Canada
I opted to unsoder the on/off switches from the esc and just put a bump of soder on the board. Pluging the battery in is my switch. Does any one think that is a bad idea? |
01-13-2011, 05:16 AM | #107 | |
That is what I would normally do, but it makes ESC programming easier having the switches. I don't have to have three hands to do it. | |
01-13-2011, 05:36 AM | #108 |
Old guy Join Date: Jan 2007 Location: Northwest Arkie-saw and we got ROCKS!
You got alot of great ideas in here. Way to go . |
01-13-2011, 06:23 AM | #109 |
Pebble Pounder Join Date: Nov 2007 Location: Alice Springs/Australia
alot of inginuity there sven nice work on the whole rig very good 5 stars
01-13-2011, 08:07 AM | #110 |
Great work Sven, certainly some ingenuity going on I love the servo mount, but the interferes with my battery tray\motor guard. Will have to find another option for steering relocation...
01-15-2011, 07:18 PM | #111 | ||
| Thanks Ricky! Quote:
Just relocate the battery . --------------- Had it's first outing/comp with the new steering and chassis. I am fairly please with it, although I didn't get to run it as much as I had hoped. I used shrink wrap on only 1 of the motor wire connectors. During a rollover that shrink wrap backed off and I lost a Micro Pro and my battery . Ended my day in short fashion. I have been running the Losi pins and VP SLW's with .7's in the rear and 1's up front, but tried out them on opposite ends and didn't really care for the widths that provided. It was 11" up front and 10.25" out back. 225 hubs up front and 335 hubs in the rear. I don't like the feel of the wide front, narrow rear. It just seems too unpredictable at times. I will be going back to the 1/225 front and .7/335 rear. I couldn't just swap tires around, because I run stiff foams in the rear. This is the current setup. Please excuse the bird's nest, old habits die hard . | ||
01-15-2011, 07:22 PM | #112 |
With the addition of some weights and some clamp-on body mounts, the truck now sits at 5lbs 0.4oz ready to run. New body mounting... |
01-15-2011, 08:17 PM | #113 |
During the time I got to see it run, it flowed over the rocks really well. Your parts will be a hit when you start selling them !! |
01-16-2011, 02:56 PM | #114 |
Truck worked really well Steven. Let me know when your ready to cut me some steering parts. |
01-16-2011, 03:43 PM | #115 |
Rock Crawler Join Date: Jul 2010 Location: VOLS!
Man you got alot of work into this thing! Looks great! Wish I could have got up to northshore sat. and checked it out.. Looking forward to hearing more about it after you can get some more run time on it... |
02-08-2011, 02:44 PM | #116 |
I want a set of these for mine.. |
02-09-2011, 07:57 PM | #117 |
The work in this thread is the sickest stuff I have seen on RCC. |
02-16-2011, 12:01 PM | #118 |
I wanna be Dave Join Date: Sep 2009 Location: Nor Cal
02-16-2011, 03:59 PM | #119 |
I wanna be Dave Join Date: Jan 2009 Location: By a lake in Thornton
Wow. This really takes the cake for conceptual originality. Sven, w/ you front shocks so far back from the axle, does the front still bite down and make steep climbs like it used to? I assume you'd have to dial in a bit more squat w/ your front geo. And really, your designs are very unique. Its like you look at everything from a very different point of view. Someday i want to get a beer or 6 in you and hear your perspective on shit LOL. And I too want your links |
02-23-2011, 07:03 AM | #120 |
Newbie Join Date: Feb 2011 Location: bronx
please let me know when these will be available thanks looks great
Tags |
sniper, t1e |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/axial-xr10/282560-crawl-spec-xr10-next-chapter-t1e-sniper.html | ||||
Crawl ANZ - View topic - Nec's xr10 | This thread | Refback | 03-06-2013 01:32 AM |
Crawl Spec XR10...Next Chapter - T1E SNIPER - Similar Threads | ||||
**** T1E Sniper **** | BTF | Chassis and Suspension | 189 | 01-21-2014 02:30 PM |
