03-07-2012, 10:11 AM | #21 |
Quarry Creeper Join Date: Feb 2011 Location: Lynnwood
| Re: Knoja's Mantis
Nobody has anything on this gear issue im having?
03-07-2012, 11:19 AM | #22 |
Quarry Creeper Join Date: Feb 2012 Location: dryden
| Re: Knoja's Mantis
rig looks good man, the mantis is my next purchase but i hafta let the old wallet get fat again, money's bin flying outa it faster than I would have liked, seems I have a problem with spending on my toys my now ex g/f told me as she walked out the door.
03-07-2012, 01:08 PM | #23 |
| Re: Knoja's Mantis
Yeah, i need to stop spending on this thing!! Just wish i knew what was going on with these gears! Hoping i dont have to spend any more money. |
03-09-2012, 09:12 AM | #24 |
| Re: Knoja's Mantis
Figured out what is making the score on the idle gear. Its the bearings that sit in the trans case cover. The two outer bearings are rubbing on that gear causing the scoring as well as the horrible noise. It seems like the hole recessed area for the bearings is not deep enough. We are talking 0.21mm off. That is just enough to cause the problem. I guess now i need to figure out how to mill the recess for the bearing or mill down the gear. |
03-09-2012, 01:06 PM | #25 |
Rock Crawler Join Date: Oct 2011 Location: smithville
| Re: Knoja's Mantis
I think you had the same problem I was having, the top link mount was sitting to Low on the pinion causing a real bad clicking and it broke my pinion and main gear, so what I did what grind down the top link plAstic piece to allow it to move more freely and since then I havent had an issue. Maybe try that.
03-13-2012, 12:25 AM | #26 |
| Re: Knoja's Mantis
Well I figured out what was going on. The bearings located in the trans case cover were rubbing on the gear. After a week of being torn apart, I finally got it back together tonight. Ran the new Brood Apocalypse S-HHK 35T and man these things are bad ass! So much more low end control and the wheel speed... Damn!!!!! Kinda afraid I'm gonna break something else!!!! Hoping it will stop raining this week so I can hit local spot and get some more time in. |
Knoja's Mantis - Similar Threads | ||||
My old XR Mantis | chopperray | Axial XR10 | 16 | 12-14-2011 08:10 PM |
My mantis | knobbytrav | Axial XR10 | 50 | 11-02-2011 11:53 PM |
Mantis XR | crawlinghulls | Axial XR10 | 10 | 11-09-2010 04:21 PM |
Mantis... | TattooKenny | Testing 1 2 3 | 2 | 01-11-2010 08:26 AM |
HD Mantis | bOAH | EnRoute Berg | 15 | 10-26-2009 12:07 AM |
