12-27-2011, 10:10 PM | #1 |
Quarry Creeper Join Date: Apr 2009 Location: sandia park, nm
| roglum's xr
first off i'd like to thank everyone who has done a build thread, you make my work much easier. so i couldn't turn down trying an xr for the price they are going for now, considering i had everything to make it run. so i built it stock down to link placement and shock oil, (except for better bearings) and i was impressed. i have been running a bully for some time now and thought i was fairly happy with how it worked, until i drove this thing. the first comp that i took it to i thought about throwing it down the rocks it worked so well. but stock is only good for so long, i needed more break-over. this is how it sat before the new chassis. duel sidewinder micros some tekin 35t 7954sh vp chubs and nuks chaotic straight tie rod avid over-sized bearings home brew battery mount new parts vp link mounts scx shocks mini springs dh2s slws ci khaos pins w/ dd foams hh torque master 35t (cleaned up from my bully) bwd motor savers chaotic crawler links progress chassis (thanks steve) got it all together and messily wired i put the escs and bec on a rowdey motor mount, only thing in the chassis is the receiver. i'm itching to drive it but there's over a foot of snow hiding my rocks. i still have to clean up the wires and install the battery mount. more to come. Last edited by Harley; 07-22-2013 at 11:43 AM. |
12-28-2011, 12:25 AM | #2 |
RCC Addict Join Date: Jan 2008 Location: Apple Valley,CA
| Re: roglum's xr progress
Lookin good man. I like how the only thing on the chassis is the rx. Your bias should be great.
12-28-2011, 09:02 AM | #3 |
RCP CRAWLERS Join Date: Nov 2007 Location: Upland CA
sweet set up ...looking great |
12-28-2011, 09:53 AM | #4 | |
| Re: roglum's xr progress Quote:
12-28-2011, 07:15 PM | #5 |
got the wires cleaned up, and added a topless rowdy battery mount. so far i am real impressed with the performance. i have a question though. i've read about internal springs for the rear to help side hilling, just the internal springs or outer springs in combo? and any suggestions for a length and rate? |
12-29-2011, 12:34 PM | #6 |
5th D Owner/Driver Join Date: Dec 2005 Location: Snoqualmie, Wa.
I run the inner RCP springs in the rear shocks only along with a green mini-t spring. RCP*Crawlers*Internal*Shock... |
12-30-2011, 01:56 PM | #7 | |
12-31-2011, 01:52 PM | #8 |
got some drive time today. works great. breaks over awesome, side-hills pretty good and it is very predictable. the setup feels pretty good so far. i'm going to try rear internal springs and maybe clock to knuckles back one more notch. only got a few pics but i think this is a pretty cool sequence. walked right up it. |
01-02-2012, 10:31 AM | #9 |
with the internal springs in the rear you will sidehill much better ...some times I even run front internals when I see a course with severe sidehilling it's all give and take....breakover vs sidehilling.....just need that happy medium |
01-02-2012, 04:54 PM | #10 |
i've got a local comp this weekend and i'm pretty sure there will be more side-hills than break overs so if i get the springs in by then we'll see how it works out. i'm real impressed with the performance so far. i'm still thinking about going to the az crawl off. we'll see.
01-02-2012, 05:02 PM | #11 |
I am definitely looking forward to seeing this perform this weekend |
01-11-2012, 03:43 PM | #12 | |
how did she do? | |
01-11-2012, 06:17 PM | #13 |
i'm in for the crawl off and looking forward to it. i hope i keep myself from making dumb mistakes. as for how it did this last weekend, great. 31 points less than the next closest. i got rcp's internal springs but they are way too big for scx shocks. so i went with pen springs. i've got some pics to post. side hilling is still a little touchy, but not too bad. |
01-12-2012, 08:48 AM | #14 | |
and see what springs will work great scores! | |
01-12-2012, 11:15 PM | #15 | |
Its a HARDKNOCKZ Life... Join Date: Feb 2011 Location: Southern Kali...
The other thing I did was move my shock mounts inboard and stood the upper links off of the chassis. This better triangulated the suspension ans gave a muxh more stable platform on the more severe sidehills. That chassis looks TINY in that pic with the Donas. J.D. | |
01-15-2012, 10:00 PM | #16 |
| Re: roglum's xr progress it is tiny. i'm running sxc shocks with silvers front and greens rear, internals in rear, 60wt front 80 wt rear. i'm pretty happy with this set-up so far. climbs like a goat, real predictable and side hills purty dang good. only issue i'm having now is when on some side hills, while turning, the downside tire will cut under and the upside tire will float, kinda like torque twist. i'm going to try some stiffer springs and see what happens. hopefully the snow will melt off my rocks so i can get some more time in before this weekend. |
03-28-2012, 09:03 AM | #17 |
made some progress on my progress. i'm now running dlux knuckle weights and slw front and rear with ci kahos pins. also made cf side plates. it's working pretty well. short comp run video. DSCN0629.mpg - YouTube |
03-28-2012, 09:16 AM | #18 |
Nice driving Your rig looks like it's working really well for you...
03-28-2012, 09:24 AM | #19 |
Quarry Creeper Join Date: Feb 2012 Location: dryden
WOW, that rig makes that course look easy with the khaos tires on it, nice build and great driving!!!!!
05-15-2012, 09:22 PM | #20 | ||
made some more changes. got a secret agent 4.0. i had made carbon progress side plates and added a few extra link holes but still felt the link geo could be a little better. i got some sweet ottsix ice links for lowers and used aluminum tube for uppers. also changed to pro-line power jokes, err power stroke shocks. all ready with shaved donas and blitz rims. good balance. d-lux main knuck weights, only added weight. weight as it sits in the pics is 4 lbs 4 oz. i was at 5 lbs 5 oz with the progress. i've had to spend some time getting used to the lighter set up. so far i like it much. this chassis is killer. right out of the box i out climbed my old one. very predictable and smooth. still have some tuning to do but it's already won a local comp. more to come. | ||
roglum's xr - Similar Threads | ||||
Progress XR | dude26 | Axial XR10 | 10 | 09-13-2011 04:01 PM |
K2-3S progress.... | bruiserin2002 | 2.2 Scale Rigs | 34 | 12-29-2006 09:03 PM |
k2-3L in progress | Cloak | 2.2 Scale Rigs | 11 | 12-29-2006 12:55 PM |
work in progress very,very slow progress! | rednekcrwlr | Tamiya Clod Buster | 6 | 12-18-2006 09:48 PM |
Some Progress | 4XADICT | Tamiya TLT Crawlers | 32 | 08-15-2005 09:34 PM |
