07-26-2012, 11:52 AM | #1 |
Rock Stacker Join Date: May 2009 Location: Ramona
| Using single esc question.
Im lost on this one. Is there a link with a wiring diagram for putting together dual motor, single esc and bec? Im using a spektrum dx3r radio. Thanks. |
07-26-2012, 12:05 PM | #2 |
Quarry Creeper Join Date: Apr 2009 Location: Long Beach
| Re: Using single esc question.
I would trying posting here for starters....RCCrawler General Tech - Electronics at RCCrawler.com . Copy and paste your ??? There... Last edited by samaruki; 07-26-2012 at 12:08 PM. |
07-26-2012, 12:16 PM | #3 |
Pebble Pounder Join Date: Mar 2011 Location: Calgary, Alberta
If you are not using a dig then just solder 2 wires to your pos motor lead on your esc and 2 to the neg.
07-26-2012, 02:18 PM | #4 | |
| Re: Using single esc question. Quote:
But since you have a 3ch radio, I'd definitely pick up a Punk or Heyok's dig switch to take advantage of a dual motor setup. Easiest way to wire a BEC into a system is to use a RX bypass adapter from CreationFab. It powers the servo directly, and there is no need to pull the red wire from your esc (which makes programming easy if you use a Hotwire or CastleLink) Last edited by TSK; 07-26-2012 at 02:20 PM. | |
07-27-2012, 09:59 PM | #5 | |
RCC Addict Join Date: Apr 2012 Location: Williamsport, PA
07-30-2012, 10:26 PM | #6 |
Thanks for the help guys.
08-03-2012, 04:20 AM | #7 |
Newbie Join Date: Nov 2011 Location: earth
I'm gonna do the same thing but make up a set of y-connectors for the motor to esc wiring so I can reverse the leads easier.
Using single esc question. - Similar Threads | ||||
RX10 on single ESC? | dcgayhart | Axial XR10 | 5 | 03-02-2012 06:18 PM |
Dual ESC vs. Single. | OFFROADRCKOREA | Axial XR10 | 19 | 02-28-2012 02:51 PM |
Dual ESC vs. Single ESC and Dig | zjguy721 | Electronics | 12 | 02-21-2011 08:08 PM |
Dual or Single ESC | cmjomaha | Newbie General | 18 | 09-08-2010 10:13 AM |
ESC Conversion help please? 3 step to ESC single battery | OldShovelhead | Tamiya Clod Buster | 0 | 07-24-2005 11:00 AM |
