04-03-2015, 02:27 PM | #61 |
Rock Crawler Join Date: Dec 2010 Location: Ct.
| Re: blandon's DLUX XR10 Build
I crawled with the rig a little and decided to lighten the load a little bit. I am not looking to do a featherweight, would just like to get it right around 4 lbs. So I am looking to lose around 10 OZ. so here goes. I saw these motor plates on Purps thread and liked them instantly so I checked out Krazed Builds (Robbob) website and ordered these and the brace under the servo. These parts look even better in person and the fit and finish is excellent. Thanks Rob!! |
04-03-2015, 02:33 PM | #62 |
The next thing I decided to change were the gears. I went with RC4WD lightweight gears and added in Axial lightweight final gear for front and rear.
04-03-2015, 02:41 PM | #63 |
Just by the tire narrowing I saved almost 2 OZ. I cut and shut 4 narrow and 4 ultra narrow so I can try different combinations and pin trimming to see what works best. Also narrowed down wheels to .75. Included a pic of stock, narrow, and ultra narrow Voodoo for people who have never seen a side by side size comparison.
04-03-2015, 02:48 PM | #64 |
I know what many of you are going to say, You would save weight by getting rid of all the VP stuff, and I know that but I like that S#%@ so I am going to see how light I can get it with the VP stuff on it. I have a ton of stock XR parts and brass inserts so if I decide to change later I can. Just want to see how this works first.
04-03-2015, 02:55 PM | #65 |
Sold my HH Torquemaster Pro motors and had Holmes build me a set of Puller 400 motors. The weight difference by changing out the 2 motors is 162 grams. That is one massive savings right there!! The motors should be here by Tuesday so I will update pics next week. Also decided to change battery location to the front axle, not for weight reasons but it was a pain in the ass to change batteries between runs.
04-03-2015, 03:11 PM | #66 | |
Rock Crawler Join Date: Jul 2013 Location: Manchester
| Re: blandon's DLUX XR10 Build Quote:
Sent from my iPhone using Tapatalk | |
04-03-2015, 03:12 PM | #67 |
That should be pretty close to your 10 oz mark maybe more just with those mods .... And you should still be safe and reliable ...nice Sent from my iPhone using Tapatalk |
04-03-2015, 03:26 PM | #68 | |
Rigs coming along good, hopefully get to go up against it someday. | |
04-03-2015, 03:29 PM | #69 |
Thanks man, it should be nice and tunable and it's nice to know I can change weight in either direction at that point.
04-03-2015, 03:32 PM | #70 |
| Re: blandon's DLUX XR10 Build |
04-03-2015, 04:06 PM | #71 |
Quarry Creeper Join Date: May 2012 Location: enfield CT
Nice build I can say I was at 3lbs 12oz. Rtr 2 years ago now I,m at 4lbs 2 oz simply from breaking alum. Screws titanium shafts and gears and replacing with steel etc. I would say my magic number is 4lbs 0 oz. even for best handling. Comcastboy "mark" has a all vp alum. Including the toppers like you and he weighs 4lbs 1 oz lighter then me and the vp bling is nice and bult prof It's really nice to see your build and how your progressing through it now we need video of it running |
04-03-2015, 04:50 PM | #72 | |
04-03-2015, 05:20 PM | #73 |
Rock Crawler Join Date: Aug 2013 Location: Norway. Bodø city
you can also turn the shocks upside down,that way you get more weight lower on the rig... just a thought |
04-03-2015, 05:43 PM | #74 |
04-03-2015, 06:41 PM | #75 | |
Or 2-56 screw in the cap with bladders and bleed the air? But there is clearance hassles upside down Im pretty sure when you articulate. | |
04-03-2015, 06:42 PM | #76 |
Oh wait - with the cap mod you would clear.
04-03-2015, 06:57 PM | #77 |
04-04-2015, 07:12 AM | #78 |
Transmission weight without light gears and carbon motor plate: 104 Grams
04-04-2015, 07:15 AM | #79 |
Tranny going together with new parts
04-04-2015, 07:21 AM | #80 |
lets see the new weight with some lightweight gears in it... if I am not very wrong I guess you landed around 92-94g |
blandon's DLUX XR10 Build - Similar Threads | ||||
Dlux fab xr10 build | dieseldee | Axial XR10 | 15 | 02-27-2015 02:28 AM |
