12-06-2016, 10:17 PM | #1 |
Pebble Pounder Join Date: Oct 2016 Location: Weatherford
| chassis issue
ok for those of you reading I just bought a new dominator 2 chassis from 5th dimension and while its awesome I also bought a link set from dlux fab for it and while it was for the bully 2.2 rtr I have I was wondering if i would be able to put the bully 2.2 rtr chassis on the xr10 since I would otherwise just have a chassis lying around if it did not fit and whether I would be better off putting which chassis on which crawler looking for feedback might should have posted this in the bully section but kind of a confusing topic either way I'm trying to put the 5th dimension chassis on the bully and the bully chassis on the xr is it would fit and how it would fit but the chassis links I bought from dlux look good on the lower links the upper are rather thin and wonder if that is normal for the uppers from dlux I have only done the one purchase and don't know from experience how they are any feedback is good feedback thanks.
12-07-2016, 04:47 AM | #2 |
Rock Crawler Join Date: Apr 2010 Location: Eastridge Tn.
| Re: chassis issue
Yes that's a normal thing fox...it's to shave some weight. All you need to do if things don't line up perfect is adjust or play with the rod ends. If they are too long cut them down....not long enough get a set of traxxas revo rod ends and replace them (I think that's what Erik uses) and you should be good. On what chassis goes where IDK what to say on that cause I don't have either :( but I know that they are both good!! Sent from my HTC One M9 using Tapatalk |
12-07-2016, 06:01 AM | #3 |
| Re: chassis issue
I really cant make heads or tails of what your saying or asking but Ill try ......... Yes. Any chassis will fit on any axle. You may have to do some link tuning by bending a little or using different rod ends to get to legal 12.5'' wheelbase if you plan on competing with it. Theres no certain way you have to build these trucks |
12-07-2016, 09:29 AM | #4 |
| Re: chassis issue
ok you both answered my question it was more or less if i swap the bully chassis over to the xr10 would things line up for the most part i know link wise i might have to re fit or change a little but yea i knew the 5th dimension chassis would fit on either just hadn't seen any one really do it before and wasn't sure and the bottom links i got from dlux are the nice thicker ones that fit with the jato rod ends no problem but the upper are so thin or narrow that i don't know really what ends to buy for it i was kinda shocked they were so thin thought maybe they were for steering instead haha
12-07-2016, 10:15 AM | #5 |
RCC Addict Join Date: Nov 2011 Location: the not so white north
| Re: chassis issue
Get the Traxxas rod end part #1942. They will work perfect for the Dlux uppers and give you options for length.
12-07-2016, 10:33 AM | #6 |
Rock Crawler Join Date: May 2011 Location: SoCal
| Re: chassis issue |
12-07-2016, 02:07 PM | #7 |
| Re: chassis issue
Well as to the above^comment ha look at the time i posted this and think how does one sound at that time of day, but on another note i think i have figured out what i will do with both and try and post something on the two or at least show pictures.
chassis issue - Similar Threads | ||||
Gcm jk chassis steering issue | mtgrizzlymn | General Scale Talk | 0 | 12-10-2013 07:52 PM |
Gelande Chassis Issue | bryco13 | 1.9 Scale Rigs | 4 | 10-10-2013 09:51 AM |
TCS Edge Chassis Issue | CountryChevy15 | Axial AX-10 Scorpion | 21 | 12-08-2011 09:45 AM |
servo/chassis issue-please help | pantablo | 1.9 Scale Rigs | 8 | 07-19-2008 08:59 AM |
Stick with 4 link chassis to clod axle issue | DrasticSports.com | Tamiya Clod Buster | 3 | 04-30-2007 11:40 AM |
