03-31-2015, 12:34 PM | #1 |
Rock Stacker Join Date: Feb 2014 Location: Elk River
| 4s top speed?
Hi, i was wondering if anybody could let me know what top speed is approximately with the stock electronics on 4s. I have looked and all i see is top speed on 6s and im trying to decide on what motor esc for my kit should be. Im thinkin of starting on 4s and see what happens. I have alot of experience with 10th scale and smaller but nothing this large thanks
03-31-2015, 12:40 PM | #2 |
RCC Addict Join Date: Mar 2013 Location: Oklahoma City
| Re: 4s top speed?
I would guess 30mph. I would recommend either the castle Mamba monster and the 2200kv motor or the Tekin Rx8 2000T8 motor. Some have used other set ups but those are the two I recommend. |
03-31-2015, 12:41 PM | #3 |
RCC Addict Join Date: May 2009 Location: Weston
| Re: 4s top speed?
I get 35mph with a tekin 2250 4038 and 17t pinion. Going to go with an 18 and check temps cause 35 isnt cutting it for me and I really dont want to go 6s.
03-31-2015, 01:13 PM | #4 |
Quarry Creeper Join Date: Feb 2015 Location: Douglasville
| Re: 4s top speed?
I am getting 41mph with 17t pinion on 4s 5200mah 40c Vicious lipo's. I am running a Castle 1515 2200kv motor and a Hobbywing Quicrun 150a esc. This setup is performs well and stays cool. (the fan on the motor is unessesary, I had it laying around and used it during assembly). The vicious battery is a perfect fit as well. Last edited by BobTeagle; 04-01-2015 at 02:56 PM. |
03-31-2015, 01:40 PM | #5 |
| Re: 4s top speed?
What did you use to check your speed? I'm curious how that motor, quite a bit slower in my ET48 then the tekin with the same gearing is running that much faster?
03-31-2015, 01:54 PM | #6 | |
| Re: 4s top speed? Quote:
As I am sure you know, alot of things can contribute to speed other than motor. Batteries, ESC, and tire size. The kit tires are slightly larger in diameter than the RTR tires. | |
03-31-2015, 02:04 PM | #7 |
| Re: 4s top speed?
I understand that. I have a kit and use Vant 8000 40c 2s packs so it's a little heavier but 6 mph is substantial. Maybe I got a bad reading. I'll have to try it again. Sent from my iPhone using Tapatalk |
03-31-2015, 02:23 PM | #8 |
| Re: 4s top speed? I agree brother. What are you using to calculate speed? Also what ESC? That is a good motor you have there.. It could be a ESC setting..
03-31-2015, 05:03 PM | #9 |
| Re: 4s top speed?
I have used my iPhone and a sky Rc gps meter. They both seem to be pretty accurate. I also use an RX8 gen 2. I'm curious to see what others are seeing? Are you using any timing? Sent from my iPad using Tapatalk |
03-31-2015, 05:11 PM | #10 | |
You have a great setup! Should do anything mine does and then some! | |
04-01-2015, 07:41 AM | #11 |
| Re: 4s top speed?
Thanks guys for the great info so far. Keep it coming if u got it! Also thanks bob for the esc motor link. I just ordered it |
04-01-2015, 09:32 AM | #12 | |
04-01-2015, 09:40 AM | #13 | |
I also recommend the program card for Hobbywing ESC's. Make programming a snap. You simply plug into the fan port. Hobbywing LED Program Card Box C for Quicrun Series Car ESC | eBay Here is the link for the bullet connectors you will need to solder onto your ESC wires that match the Castle Motor wires. New Castle Creations 6 5mm Bullet Connector 13g 8g 200A 3 CC Bullet 6 5mm | eBay | |
04-03-2015, 06:46 PM | #14 | |
04-03-2015, 07:05 PM | #15 |
| Re: 4s top speed?
This might be helpful In case you have not soldered bullet connectors https://m.youtube.com/watch?v=B9yY9Kk4bEA |
04-08-2015, 02:50 PM | #16 |
| Re: 4s top speed? |
04-08-2015, 03:20 PM | #17 | |
I wanna be Dave Join Date: Jan 2009 Location: By a lake in Thornton
The best part is it reaches that speed in like 1.5 seconds. | |
04-08-2015, 04:44 PM | #18 | |
Setting Item Value 1 2 2 1 3 5 4 9 5 2 6 1 7 2 8 1 9 4 10 1 11 1 12 4 Hope this helps brother | |
04-18-2015, 09:39 PM | #19 | |
What programmer so you use? This one HOBBYWING TECHNOLOGY CO., LTD. doesn't list the Quicrun. Thanks for answering all my HW questions. | |
04-19-2015, 08:42 AM | #20 |
Rock Stacker Join Date: Mar 2015 Location: uk
| Re: 4s top speed?
You need the cheaper LED box not the LCD for the latest 150a HW.
4s top speed? - Similar Threads | ||||
Gearing and top speed | AussieCrawl | U4RC | 19 | 10-12-2014 01:03 AM |
Top Speed | jprock | Losi Micro-Rock Crawler | 6 | 12-14-2012 08:03 PM |
Top speed | demonoid369 | Chit Chat | 13 | 10-20-2011 08:30 AM |
Top speed on Honcho | 0lllllll0 | Newbie General | 9 | 11-30-2010 04:59 PM |
top speed | oko0913 | Axial SCX-10 | 8 | 10-22-2010 10:18 PM |
