Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Yeti XL
Thread: Finished!
Old 03-24-2017, 05:10 PM   #1
Default Finished!
Thanks to everyone who helped me with my first kit glitches!
It's finally finished and I took it out for a first bash today, it was flawless
It doesn't compare to tphjill's and others but I'm very happy with it and it's a welcome addition to the family.
http://www.rccrawler.com/forum/attac...1&d=1490396858
Cheez is offline   Reply With Quote
Old 03-24-2017, 06:23 PM   #2
Default Re: Finished!
What are you taking about! It's freaking awesome! Love the paint job!
tphjill is offline   Reply With Quote
Old 03-24-2017, 09:58 PM   #3
came out nice man. You still have to back that paint with another color. Light if you want maximum brightness, dark if you want to add some sinister to it.
Lavaheadache is offline   Reply With Quote
Old 03-25-2017, 08:03 AM   #4
Nice work!
Barndog Racing is offline   Reply With Quote
Old 03-25-2017, 04:05 PM   #5
Awesome job. FWIW watch those plastic shock caps. I broke mine early after my build. Went to DHAWK aluminum and they are flawless.
pro mod steve is offline   Reply With Quote
Old 03-25-2017, 05:08 PM   #6
Those are next on the to do list.
Are reservoir caps worth getting?
Old 03-25-2017, 07:01 PM   #7
I just use the standard cap. I use a bladder in cap rather than the supplied o-ring. Team Associated #89351
Old 03-26-2017, 11:40 AM   #8
I'm thinking about getting HR shock caps , any opinions out there regarding "piggyback reservoir " type vs. "bleeder" ?
Old 04-10-2017, 01:49 PM   #9
Looks clean. I really like the wheel/tire combo.
What wheels are they?
Adidas4275 is offline   Reply With Quote
Old 04-10-2017, 04:12 PM   #10
Thanks,
3.8 Falken Wildpeak M/T tires and 3.8 Raceline wheels.
http://www.rccrawler.com/forum/attac...1&d=1491862316
Old 04-12-2017, 12:04 PM   #11
Oops!! :(
http://www.rccrawler.com/forum/attac...1&d=1492020242
Old 04-12-2017, 12:12 PM   #12
Circumstances? I'd like to know how not to do that...
mtr1514 is offline   Reply With Quote
Old 04-12-2017, 12:25 PM   #13
No punch control. High C batteries or tight mesh can lead to this. That's why I had a mod one conversion made but if I don't see any interest I'll be the only one running them.
BarHarborBasher is offline   Reply With Quote
Old 04-12-2017, 01:53 PM   #14
Batteries are 25 C, was only about five minutes into rock crawling with a couple of 75% throttle pulls on adjacent asphalt walkway. Probably was the mesh. Pinion came loose on my last run, thought I had a good mesh but apparently not. :(
It cursed me on that second punch.
Old 04-20-2017, 05:59 PM   #15
My stock Tactic servo has died and gone to servo heaven
I'm considering getting Hitec HS-7950TH HV Ultra-Torque Titanium Corless Servo. I realize there are a million opinions on servos (I've checked the threads)
Promodeler 420 is out of stock, Holmes seems a good option. Appreciate any thoughts.
Old 04-20-2017, 10:38 PM   #16
My stock tactic servo died too, Cheez. I just ordered a Savox 1270TG, which should be here in the next few days. I did a TON of reading through the forums, and you're right, everyone seems to have a different opinion. I made my selection after a few PM's with a couple members and they've both run this particular one over a year with no problems. I bought a new gear set for the stock tactic for $10 the other day and just installed it tonight. It functions great, and my plan is to just keep it for a backup. The gear that shredded in mine, (and likely yours), is a single plastic gear. The new gear set still contains the plastic one, but for a backup, I figured why not.
CptSummersausage is offline   Reply With Quote
Old 04-20-2017, 11:56 PM   #17
Thanks, that looks like a very good option.
I'm not sure what "Special design for high voltage native 2s LiPo operation." In the tech description means. Will it be fine with 2x3s?
Where did you buy the gear set?
Old 04-21-2017, 05:53 AM   #18
2S lipo operation has nothing to do with 2x3S. 2x3S is what you are running the truck on (and it is what it is) and 2S lipo operation is the voltage on which your servo is running on (and you can choose it from the ESC/BEC setup).
Tzicul is offline   Reply With Quote
Old 04-24-2017, 10:17 AM   #19
So that's the part that gets a little tricky. It'll depend on your stock ESC BEC output. If you have the Yeti XL RTR, your stock BEC output is 5V. Which means if you run that Savox servo I bought, you're likely going to experience "brown outs" or shuttering because it'll draw more power than your stock ESC can handle. What you'll need to do, is install an external BEC (I bought the 10A one from Castle Creations) and do a little bit of soldering to get it hooked up. Then, you can program the new BEC to whatever voltage output you'd like (up to the servos max recommendation). There are a lot of videos you can watch that are helpful with the installation of everything.
This video I found to be the most helpful:
https://www.youtube.com/watch?v=X-oIAPIlDjc
Things I needed to do this project:
Castle Creations Castle Link
Holmes Hobbies RX bypass
Castle Creations 10A BEC
Savox 1270TG Servo
Kind of disappointing that I needed to do this to what I was really hoping to be a bullet proof truck, but at the same time it was a fun little project. Good luck!
**Edit: I forgot to answer your question about the tactic gear set. I ordered it off amazon.
Old 04-24-2017, 11:17 AM   #20
Thanks for the info, I decided to get the Hitec HS-7950TH HV Ultra-Torque Titanium Corless Servo.
I am using the stock Vanguard AE-4 ESC, I'm totally green when it comes to electronics, am I going to have issues to deal with? Is a BEC a "must have "?
Finished! - Similar Threads
Ever Done This? (finished!) monkeyracing Tamiya XC/CC01 4 05-07-2014 10:17 PM
just finished w.k fast625 HPI Wheely King 0 08-17-2008 10:06 PM
Finished CLODMAN360 Tamiya Clod Buster 1 05-29-2006 11:59 AM
almost finished yamaharider308a General Crawlers 2 04-16-2006 09:18 PM
TLT finished! Half aluminum tube High gc Low cg FINISHED RCMFMaxxMan Tamiya TLT Crawlers 12 08-08-2005 12:18 AM
