07-21-2014, 11:32 PM | #101 |
RCC Addict Join Date: Nov 2008 Location: Santa Fe, NM
| Re: Harley's #AxialYeti
Skins look amazing! |
07-21-2014, 11:36 PM | #102 |
Love the skin. Much better than stock.
07-22-2014, 03:47 AM | #103 |
Quarry Creeper Join Date: Oct 2011 Location: liberty
That looks so much better than stock. Great job :-)
07-22-2014, 05:12 AM | #104 |
Rock Crawler Join Date: Mar 2008 Location: 920 Valley of the Fox
The rig and skins look great! However it is a bit less ORANGE than I expected for a Harley rig... |
07-22-2014, 06:29 AM | #105 |
I wanna be Dave Join Date: Jul 2010 Location: Toronto
Looking good sir. Already have my order with Neal in!
07-22-2014, 08:24 AM | #106 |
nice touch on the roof, triple riped colors nod towards the stock paint job, yet being totally different.
07-22-2014, 06:07 PM | #107 |
Rock Crawler Join Date: Jun 2013 Location: Knox, IN
Lookin good there Harley!
07-22-2014, 06:08 PM | #108 |
So when does it get the LED setup?
07-22-2014, 06:13 PM | #109 |
| Re: Harley's #AxialYeti |
07-23-2014, 12:51 AM | #110 |
How well did the glue up wheels do? I love the look of them, but have been leary to buy them because of the non-beadlock design. Great write up on the event and the rig. |
07-23-2014, 06:34 AM | #111 | |
Newbie Join Date: Mar 2014 Location: Fairfax
| Re: Harley's #AxialYeti Quote:
Also, if you are replacing the bell cranks, avoid the STRC set. The angle between the two arms on the right side is too wide, which leads to needs lots of modification. Also the STRC carbon fiber rack sometimes hits my diff cup. | |
07-23-2014, 07:42 AM | #112 |
| Re: Harley's #AxialYeti They did great, this set is actually owned by Crawler Innovations. He sent me his personal test set to give me the chance to test them out at the G6. The advantage to these on this car would be the amount of offset you can clear. I was running 225's and had enough room to probably drop down the the 185's that Locked Up makes.
07-23-2014, 07:49 AM | #113 | |
The distance between the bell cranks in this car are the same as the Exo, so some mixing and matching is an option but the size of some of the components are not the same. For anything like how I ran this car, more upgrades than simply changing the spring and turnbuckles are going to be needed. I can promise you that. | |
07-23-2014, 09:25 AM | #114 |
I am aware that they are different but judging by the parts list it looks like the bulkhead, diff and steering linkages are all the same. In fact the servo mounts and servo linkage area also the same, leading me to believe the servo sits identically in the chassis as it did on the EXO. In that respect the Traxxas slash Turnbuckles should fit as long as the rod end fits in the new rack. As you said the steering assembly itself is a little different, but the measurements all match the EXO, so the beefed up aftermarket parts will likely fit, though won't all be advisable. You were discussing using existing EXO replacement parts which is why I mentioned those items. Last edited by if0rg0t2remember; 07-23-2014 at 09:29 AM. |
07-23-2014, 02:06 PM | #115 | |
Quarry Creeper Join Date: Dec 2011 Location: spokane
07-23-2014, 02:08 PM | #116 |
07-23-2014, 02:33 PM | #117 |
Pebble Pounder Join Date: Dec 2013 Location: Derby Line
using .225 in front and .475 in thw back, was the width the same front and rear? Any video of the race? |
07-23-2014, 05:46 PM | #118 |
Ok I am going to order 225 and 475 Vanquish hubs. My question is, how do the stock wheels preform? I have used Axial plastic beadlocks with good luck keeping the tires on the wheels. But I hav never used this type of Axial beadlock with the hubs. I run Vanquish slw wheels on my wraith. But have other upgrades I want to add to my Yeti right off the bat. And maybe a set of KMC or Methods after bank account heals a bit. I am sure a lot of us are in the same boat here. Thanks :-)
07-23-2014, 07:02 PM | #119 |
Quarry Creeper Join Date: Mar 2013 Location: Pilipinas
luckster, the 225 and 475 hubs you're getting are measurements for the stock wheels right?
07-23-2014, 07:32 PM | #120 |
Dextan22 yes for the stock the walker evans beadlocks
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/axial-yeti/501486-harleys-axialyeti.html | ||||
Axial 1/10 Scale Yeti Rock Racer (IFS front/Solid rear) - RC Rock Crawlers & Scalers @ URC Forums | This thread | Refback | 07-26-2014 05:04 PM |
Harley's #AxialYeti - Similar Threads | ||||
Harley's Wrexo | Harley | Axial Wraith | 94 | 06-22-2014 10:01 PM |
Harley's Willys | Harley | Large Scale Rigs | 33 | 10-16-2012 12:24 PM |
Harley's FJ X-Trail | Harley | 1.9 Scale Rigs | 198 | 09-23-2009 11:07 PM |
Harley's 2.2 Stick | Harley | Tamiya Clod Buster | 42 | 03-06-2008 01:51 PM |
