09-17-2014, 11:47 AM | #21 |
Rock Crawler Join Date: Feb 2007 Location: Crawling Around
| Re: a quick cheap fix for the crappy front links..
Not sure yet. We are fitting our rear axle in the Yeti and some other stuff, so I'm sure you'll see some updates soon.
09-17-2014, 12:10 PM | #22 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
| Re: a quick cheap fix for the crappy front links.. Looks aren't the only thing that means anything when it comes to welding. I can weld you an immaculate bead that won't hold from the weight of a fly. Strength > Looks. Plus there is VP and BMRC making machined aluminum options. Just a heads up, the Mod's here do not take kindly to trashing on a vendor. |
09-17-2014, 01:32 PM | #23 |
Rock Crawler Join Date: Mar 2012 Location: bel air
Wasn't trashing, and didn't name names.. Simply said I wasn't impressed with the looks of an item I saw. If that general statement crosses a line, then the line is in the wrong place. Sent from my iPhone using Tapatalk |
a quick cheap fix for the crappy front links.. - Similar Threads | ||||
quick fix for motor clearance | redcat1 | Redcat Crawlers | 6 | 02-25-2012 06:56 PM |
My Quick Fix For CVD Pins | slackerman | Venom Creeper | 12 | 11-11-2009 06:50 AM |
New here, driveshaft CV problem, quick fix?? | theothertoymaker | Team Losi Comp Crawler | 1 | 08-10-2009 01:54 AM |
quick fix | fishnstash | Axial AX-10 Scorpion | 1 | 07-27-2008 09:49 AM |
quick fix for the drive shaft | BEAU | Axial AX-10 Scorpion | 23 | 09-21-2007 02:05 AM |
