09-10-2014, 08:42 PM | #1 |
Rock Crawler Join Date: Mar 2012 Location: bel air
| a quick cheap fix for the crappy front links..
the traxxas slash 4x4 turnbuckle links are damn near an exact replacement for the plastic steering and toe links and are readily available on ebay for less than $10 per set of 6
09-10-2014, 08:50 PM | #2 |
Rock Stacker Join Date: Jul 2014 Location: Pearland, Tx
| Re: a quick cheap fix for the crappy front links..
By damm near that implies a slight mod, so what do they need to fit?
09-10-2014, 08:51 PM | #3 |
a small wrench to adjust the turnbuckle.... haha... i looked at the sct and its off by only a few mm. i have a few sets im bidding on right now. uahobbies starts the bidding at .99 a set and they usually go for $3-5. i have used these links on a bunch of builds and they come in handy once again
09-10-2014, 09:19 PM | #4 |
Awesome, coming from touring cars I was surprised to not have adjustable links
09-11-2014, 03:39 AM | #5 |
Rock Crawler Join Date: Jan 2006 Location: Bellaire, MI
I don't think Axial makes an adjustable turnbuckle for anything. They may not even know what one is...
09-11-2014, 07:06 PM | #6 |
RCC Addict Join Date: May 2009 Location: Weston
I used Durango TD310215 and traxxas ends. Works great!
09-12-2014, 07:25 AM | #7 |
Pebble Pounder Join Date: Feb 2013 Location: Mid Missouri
Just to throw some part numbers at it for the non-traxxas folks, here's what I think I've found: 3643 - 82mm Center to center 3644 - 69mm Center to center 5539 - 90mm C2C (??? unconfirmed source) 3745 - 78mm C2C (Stampede / Rustler Turnbuckle) Seems to me that the 3745 is the closest drop in replacement (unless I'm missing something, I don't have anything in hand yet & haven't had a Traxxas in 10 years) |
09-12-2014, 08:33 AM | #8 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
Traxxas 3643 installed (you have to replace 2 of the included balls for the steering rack side and 2 for the hub for the upper link for standard Revo ones). Threading the Jato rod ends on further makes them stronger. If you only run them on like a Revo which is about 10mm you end up with a long hollow tube in the rod end that can break. Not the case when the rods are threaded in deep like on how the 3643 ended up on the Yeti. |
09-12-2014, 08:36 AM | #9 |
Just curious, why did you have to replace the ball ends?
09-12-2014, 10:57 AM | #10 |
| Re: a quick cheap fix for the crappy front links.. |
09-12-2014, 12:10 PM | #11 |
09-12-2014, 06:14 PM | #12 |
5th D Owner/Driver Join Date: Dec 2005 Location: Snoqualmie, Wa.
09-15-2014, 06:24 PM | #13 |
| Re: a quick cheap fix for the crappy front links.. $2.75 + shipping... I did switch one of the ends out for a shorter one on the camber link so I would have room for adjustment, the longer link would work if I screwed it all the way in though, just no more room if you want a degree or two of negative camber. Sent from my iPhone using Tapatalk |
09-15-2014, 06:33 PM | #14 |
Rock Crawler Join Date: Feb 2007 Location: Crawling Around
This thread is why forums rock. |
09-15-2014, 06:54 PM | #15 |
thanks.. if youre interested, go to uahobbies on ebay, they are the cheapest chop shop on there and the only place that ships faster is rpp...
09-17-2014, 09:45 AM | #16 |
I searched, and uahobbies got me nothing at all. Can you post a link?
09-17-2014, 09:47 AM | #17 |
09-17-2014, 10:08 AM | #18 |
Newbie Join Date: Jul 2014 Location: callahan
I have been using HPI turnbuckles. I'm thinking all the major players have some out there.
09-17-2014, 10:24 AM | #19 |
post the link if there is a deal to be had
09-17-2014, 10:27 AM | #20 |
is gcm going to have a rear link coming...? other parts? i about ready to start bending some tube and sheet metal and make some soon. the metal ones ive seen look suspect at best. no names but the welds looked pretty bad....
a quick cheap fix for the crappy front links.. - Similar Threads | ||||
quick fix for motor clearance | redcat1 | Redcat Crawlers | 6 | 02-25-2012 06:56 PM |
My Quick Fix For CVD Pins | slackerman | Venom Creeper | 12 | 11-11-2009 06:50 AM |
New here, driveshaft CV problem, quick fix?? | theothertoymaker | Team Losi Comp Crawler | 1 | 08-10-2009 01:54 AM |
quick fix | fishnstash | Axial AX-10 Scorpion | 1 | 07-27-2008 09:49 AM |
quick fix for the drive shaft | BEAU | Axial AX-10 Scorpion | 23 | 09-21-2007 02:05 AM |
