10-05-2014, 03:58 PM | #1 |
Newbie Join Date: Sep 2014 Location: Central Indiana
| Carwling with a Yeti Can a Yeti be made to crawl as good as a Wraith? |
10-05-2014, 04:03 PM | #2 |
Quarry Creeper Join Date: Jan 2013 Location: Vancouver, B.C.
| Re: Carwling with a Yeti
The belly will always be lower, otherwise, it crawl pretty well when setup for it.
10-05-2014, 04:36 PM | #3 |
5th D Owner/Driver Join Date: Dec 2005 Location: Snoqualmie, Wa.
| Re: Carwling with a Yeti |
10-05-2014, 05:00 PM | #4 |
Quarry Creeper Join Date: Mar 2013 Location: Pilipinas
I tried it last weekend, disconnected the sways, roc412 1200kv in 4s, 500k diff oil, rockbeasts --- the balance throws it off, for me unless you tweak it specifically for crawling, not just si ple changes, it's a no go for crawling.
10-05-2014, 05:33 PM | #5 |
RCC Addict Join Date: Feb 2014 Location: Mt. Juliet, TN
I disagree. The Wraith wasn't meant to be a crawler either but it does pretty damn well at it. Like mentioned, the belly is the problem when it come to crawling. It takes a different approach at times and a different driving style but it can crawl pretty damn good when set up right. I've yet to meet a rock that my Wraith got over that the Yeti has not but the Yeti has gone over some rocks that my Wraith hasn't.
10-05-2014, 05:42 PM | #6 | |
Rock Crawler Join Date: Feb 2012 Location: Tennessee
| Re: Carwling with a Yeti Quote:
10-05-2014, 05:53 PM | #7 |
Rock Stacker Join Date: Aug 2014 Location: Somerset
Just bought one myself for this very reason. More of a rock bouncer experiment, but I think it will work out great with some trial and error
10-05-2014, 06:02 PM | #8 |
Depend on what you crawl on..
10-05-2014, 06:36 PM | #9 |
Newbie Join Date: Sep 2014 Location: Manassas
I used an almost bone stock one on a G6 and it did great.
10-07-2014, 04:13 PM | #10 |
Rock Crawler Join Date: Dec 2013 Location: Tuxedo NY
If going fast and using a lot of speed and momentum can be considered crawling, then yes. It can overcome many obstacles that other cars cannot. I have also seen a few tight technical sections that other cars lithely crawled though that the yeti had no hope of passing. It really does quite well on the rocks if it's strengths are utilized, rather than being changed or modded into something else. |
10-07-2014, 05:06 PM | #11 |
What Tutrtlejon said ^^, unless you call 'that' crawling...
10-07-2014, 05:55 PM | #12 |
Rock Crawler Join Date: Nov 2010 Location: the 'burgh'
I am of the opinion that if the rig is used for it's intended purpose, there would be no gripes, complaints or questions and they would really enjoy what it is capable of. I'm not being a dick but folks should quit trying to morph it into something it's not. That being said, whoever spends their hard earned money on a Yeti can do whatever the hell they please with it. |
10-07-2014, 10:24 PM | #13 |
Quarry Creeper Join Date: Dec 2011 Location: spokane
The rc world is weird when it comes to the word "crawling" in 1.1 it's called wheeling or trail running. Unless u are doing a a comp or something. Rc crawling is for moa rigs. So yes it can wheel or trail run just as good as the rest when built right. Shot I bet box stock to box stock it might do better than.
10-07-2014, 11:27 PM | #14 |
Give me the same budget between the Yeti and a Wraith and I can guarantee the Wraith will crawl better, full throttle assaults at everything to get the big belly pan over is not what I would consider crawling.
10-08-2014, 09:01 AM | #15 |
I can take a crap in a box and mark guaranteed, but a guarantee is only as good as the man that wrote it. I come from real life stuff wheeling u4 type. I've been scaling with rc stuff for a long time but what is crawling in the rc world? This is a serious question so I can better understand.
10-08-2014, 09:07 AM | #16 |
look at that flex! |
10-08-2014, 09:17 AM | #17 |
| Re: Carwling with a Yeti So when we go wheeling/trail running and a few u4 rigs show up to do a day run with us. Is that not "crawling" bc they might need a different driving style in some areas?
10-08-2014, 09:19 AM | #18 |
10-08-2014, 10:48 AM | #19 | |
We can have this pissing match all day long, the Yeti isn't a Wraith but it can be set up to crawl pretty damn good IMO. | |
10-08-2014, 10:48 AM | #20 |
| Re: Carwling with a Yeti I come from a comp crawler back ground and to me that is crawling, going slow over technical obstacles on rocks. G6 and Ultra4 is where the Yeti will be best at, and for the record I do own both the Wraith and Yeti along with multiple scalers and Ultra4 cars. I guess everyones idea of crawling is going to be different.
Carwling with a Yeti - Similar Threads | ||||
Yeti, Set, GO!!! FastEddy Bearings for the Axial Yeti | FastEddy | Axial Yeti | 13 | 04-21-2015 07:33 AM |
water yeti.. calling all yeti owners | going2fast | Axial Yeti | 11 | 11-02-2014 05:43 PM |
Yeti | Jimbow | Axial Yeti | 6 | 08-29-2014 12:54 PM |
Yeti | CKRC Hobbies | CKRC Hobbies | 0 | 07-30-2014 11:11 PM |
